Thread: Running lean tryed everything
  1. Running lean tryed everything
    Mar 2016
    Michigan
    So i have an audi a4 1.8t aeb engine and i am lost where to go now i cant get my system out of limp mode it hes a front mount intercooler stock ecu stock turbo aftermarket intake ive cleaned maf sensor cleaned throttle body no vac leaks but system runnig real lean will only boost max about 4 psi i run 93 octane i hade a leaky fuel injector seal so i replaced them all today no difference dont think there is a vac leak on vag com lite only codes i get are p0102 p1198 and p0140 i dont have a cat or post cat o2 have a brand new pre cat o2 sensor in though
  2. Re: Running lean tryed everything
    Mar 2016
    Michigan
    Is it possible that i have to big of a blow of valve?
  3. Running lean tryed everything
    scotland
    39 Post(s)
    You still need the post cat 02 sensor for the fuelling.
    The only way you can run properly without it is with a remap.
    Edit, AEB doesn’t have post cat sensor my apologies.
  4. Re: Running lean tryed everything
    scotland
    39 Post(s)
    P0102 Mass Air Flow (MAF) Circuit Low
    P1198 O2S Heater Circuit Bank 1 Sensor 2 Electrical Malfunction
    P0140 Audi HO2S12 Sensor Circuit No Activity Detected OBDII Engine Light Trouble Code | Engine-Codes.com
    The best approach would be to clear the codes and see which ones come back and deal with them, hopefully some of them will be old and won’t come back.
  1. Audi S6 running lean
    By alinomie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-09-2010, 04:59 PM
  2. running lean 17544 + revs higher 16891
    By blackpool1974 in forum VCDS - Help Requests
    Last Post: 19-09-2009, 08:12 PM
  3. Please Help Golf 1.6 SE 8 Valve Running lean
    By obx102 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-12-2008, 03:15 PM
  4. Please Help MK3 ABF Running too Lean
    By Golf-Fiend in forum Golf MK3 - 1993 - 1999
    Last Post: 09-05-2008, 05:50 PM
  5. S6 "Left bank running lean"
    By toff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-08-2007, 01:42 AM
