Thread: mmi 3g head unit
  1. mmi 3g head unit
    May 2009
    cornwall
    I've got a mmi 3g multimedia disc/ sd reader that is faulty, will not suck the disc in, vcds says cd mechanism will not initialise, so I got a second hand unit and fitted it, I now get component protection working.
    Contacted 2 Audi dealers (Truro and Plymouth) and both are pretty unhelpful saying they can't remove the cp, any ideas anyone?
  2. Re: mmi 3g head unit
    warp_speed Guest
    Quote Originally Posted by mogsy View Post
    Crap, they can remove component protection from the unit. Ideally a new unit would have some PR code (?) that they can type in to their system but I've never came across a dealership that couldn't remove CP, provided the replacement unit hasn't been reported as stolen or defective.
    Could you not swap over the drive mechanicals to repair your existing unit.... it probably is better just to replace the whole unit.
  3. Re: mmi 3g head unit
    May 2009
    cornwall
    I think someone has had a go at repairing it previously, the soldering on the ribbon cable motherboard end is apalling!
  4. Re: mmi 3g head unit
    May 2009
    cornwall
    Well, finally got component protection removed, found a VAG specialist in Redruth called AVS, they have all the VAG group software and fixed it in an hour.
    I would thoroughly recommend these guys to anyone in Cornwall who needs software coding (or anything else) where Audi won't oblige.
  1. MMI head unit...
    By matrixpt in forum VCDS - General Questions
    Last Post: 01-06-2014, 12:14 AM
  2. MMI 3G head unit problem
    By Stonner in forum In Car Entertainment
    Last Post: 21-01-2014, 07:37 AM
  3. Fitting new mmi control head unit
    By lukes19 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-03-2012, 10:45 PM
  4. How To Replace Concert I Head Unit With Aftermarket Unit
    By Peter Lavoie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-05-2011, 05:08 PM
  5. New head unit
    By paul3smith in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-12-2007, 10:25 PM
