Thread: VCDS Help needed
  1. VCDS Help needed
    Jul 2009
    kent
    Hi. Please can anyone help. I have a airbag fault on startup on my car. Its a passat r-line 10reg
    This was the original fault from the scan
    1 Fault Found:
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
    008 - Implausible Signal - MIL ON
    I had this looked at by a garage and they checked the wiring and changed the door sensor. I am still getting the fault. Is there someone in the kent area that can help clear this fault using VCDS for some beer tokens.
  2. Re: VCDS Help needed
    Aug 2007
    New Romney Kent
    01221 - Crash Sensor Side Airbag; Driver Side (G179): Implausible Signal
    Possible Symptoms
    • Airbag Warning Light ON
    Possible Causes
    • Wrong/Incompatible Crash Sensor Side Airbag; Driver Side (G179) installed
    • Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179) faulty
    Possible Solutions
    • Check Crash Sensor Side Airbag; Driver Side (G179) Part Number
      • Install correct Crash Sensor Side Airbag; Driver Side (G179)
    • Check Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179)
    Has the light always been on / has the sensor been changed?
    I am in Hawkinge (Folkestone) if that is not too far?
    VCDS HEX-NET registered owner (Covers all VAG cars)
    PM me if you require scans or adaptations doing in S.E. Kent, can unlock SFD.
    Audi TTS 8S
    VW ID.3 Tour
  3. Re: VCDS Help needed
    Jul 2009
    kent
    Hi Gizmo. Yes light was on when I bought the car. Door crash sensor has been changed. Folkestone isn't too far if I can't find anyone more local.
  1. A7 60 Reg, VCDS help needed
    By JayNana in forum VCDS - Help Requests
    Last Post: 09-01-2016, 11:09 AM
  2. Sheffield VCDS help needed
    By gmerifield in forum VCDS - Help Requests
    Last Post: 15-11-2014, 08:41 PM
  3. Please Help VCDS Help needed
    By Davehindley in forum VCDS - Help Requests
    Last Post: 23-07-2014, 07:33 PM
  4. VCDS needed in Bristol
    By minty2013 in forum VCDS - Help Requests
    Last Post: 04-09-2013, 09:49 AM
  5. VCDS help needed please!
    By HalD in forum VCDS - Help Requests
    Last Post: 13-01-2011, 02:57 AM
