Thread: Hi everyone - multitronic adaptation memories problem
  1. Hi everyone - multitronic adaptation memories problem
    Feb 2016
    Southampton
    decided to join so I would like to say hello everyone.I would say sorry for my English but I'm foreigner . I've got audi a5 2.7tdi multitronic :/ and just replaced radiator . After that I tried do adaptation of my gearbox but cannot memories it.My adaptation is successful but after engine off It loose adaptation. Everything going good until step 9 I don't now what to do after step 8 what is terminal 15? . I done this procedure:
    (0AW Self-Diagnosis Clutch Adaptation Instructions
    Select the following measured values in the self-diagnosis and possibly save them under Favorites:
    ^ Adaptation of the forwards start-up behavior [LO] State
    ^ Adaptation of the backwards start-up behavior [LO] State
    ^ Transmission fluid temperature
    ^ Specified clutch torque
    Creep adaptation of the forward and reverse clutch with 0AW gearboxes:
    1. Make sure that there are no fault entries in the TCM.
    2. Warm up the gearbox to about 85°C, ideally by pulling away in driving mode D and R at various loads of max 1500 rpm.
    Tip: Currently the adaptation is only possible when the measured value transmission temperature is between 80° - 95°C.
    3. When the vehicle is standing still, select driving mode D.
    4. Pull away with little acceleration to about 6 mph or 10 km/h. Slowly brake the vehicle with the foot brake.
    Hold the brake pedal for another 5-10 seconds as the vehicle stands still.
    5. When stopping, the specified clutch torque must not drop below 20 Nm, otherwise the adaptation fails.*
    If this is the case, change the driving profile (less load, gentler braking).
    6. Repeat step 4 until the measured value indicates the adaptation of the forwards start-up behavior is successfully completed.
    7. With the vehicle standing still, select driving mode R.
    8. Repeat step 4 until the measured value indicates adaptation of the backwards start-up behavior is successful completed.
    When stopping, the specified clutch torque must not drop below 20 Nm, otherwise the adaptation fails. If this is the case,
    change the driving profile.
    9. After a terminal 15 reset, the adaptation starts over again with status running. Keep the ignition switched on*
    for at least six minutes after a successful adaptation .
    Anyone have this problem before? Many thanks.
  2. Re: Hi everyone - multitronic adaptation memories problem
    Jul 2018
    Lithuania
    Hello,
    Have you resolved your issue? I have same problem and can not solve it. Your help would be awesome
  3. Re: Hi everyone - multitronic adaptation memories problem
    Feb 2016
    Southampton
    No mate . Unfortunately nobody helped in this forum either garage. Been drive like that over a year and then the car been sold .
  4. Re: Hi everyone - multitronic adaptation memories problem
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    Quote Originally Posted by diegokarol View Post
    And did you post it in the right section?
  1. Awful memories
    By Crasher in forum Chat - Completely Off Topic
    Last Post: 02-10-2010, 01:12 PM
  2. multitronic problem
    By faceman222007 in forum Chat - Anything with wheels
    Last Post: 27-06-2008, 08:36 PM
  3. multitronic problem
    By faceman222007 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-06-2008, 09:46 PM
  4. a4 multitronic problem
    By a4god2ulot in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2007, 02:52 PM
  5. multitronic problem
    By navman23 in forum Archive posts
    Last Post: 18-04-2007, 11:56 AM
