Re: Please reduce engine oil –
22-02-2016,01:32 PM
Originally Posted by
Redcar01
My Audi A4 Avant 2.0 Tdi has a message on the Mmi says Please reduce engine oil when i check it on the Mmi display , it was last filled up when it was serviced last october by dealer. Is this serious do i need to take it back and get it checked ?
Is there a way to check the oil level ?
This could be serious, take it back. Have you noticed coolant level dropping slightly?...
This way you get oil level reading on dis, check if they match with MMI
1.After drive, stop and shut off the car on evenground
2. After 3-5 minutes pull the bonnet release and open drivers door
3.Switch ignation on(dont touch pedals or start the car)
4.Press reset button on the right lever twice etc and oil level should appear in DIS.
A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
