Thread: Headlights heater wipers indicators and horn not working
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Headlights heater wipers indicators and horn not working
    #11
    May 2016
    Madbury, USA
    I have a 2005 Allroad with this same probem. I bought another relay from Audi and replaced it. It did not work. I then replaced the ignition switch. That didn't work either. So now I have real problem. Those items on my car do not work and I have exhausted all options.
    Help! Is there something else I am missing? Short of having a bad relay I purchased from Audi I don't know what else to try.
    Steve
  2. Re: Headlights heater wipers indicators and horn not working
    #12
    Highlands
    12 Post(s)
    Hi all
    I posted this thread nearly 2 years ago. I recently had the same symptoms again but forgot that I’d had the issue previously and then searching the internet for a solution was quite surprised to see someone had exactly the same issue on a car exactly the same age and spec as mine only to see annoyingly the solution wasn’t posted then I realised the someone was me! Age doesn’t come alone!
    Anyway I couldn’t remember what I did to fix it . A search of eBay purchases showed I’d purchased an ignition but I didn’t actually fit it and I also changed the relays earlier in the thread . The problem wasn’t rectified but seemed to disappear after a short time and has been fine for nearly 2 years.
    Now the issue has returned . First symptom although may be unrelated I had a bulb blown error on the dash. Took car home and went to use a few hours later only to find no build errors but no headlights wipers heater etc .
    Tried it a few times but nothing changed . I ran a vcds and no relating error codes were present.
    I then resigned to investigating further this weekend in the daylight only to find when I started the car today All is fine!
    So I now have an intermittent problem . I’m assuming I can now rule out fuses as they are either good or blown . Will the same apply to relays? Is the fault more likely to be a bad connection on an ignition wire ?
    Anyone else had this issue?
    as always any help much appreciated
    cheers
    vin
  3. Re: Headlights heater wipers indicators and horn not working
    #13
    Highlands
    12 Post(s)
    I’ve stripped it down to get ignition switch out . Is it ok to reconnect battery with airbag and steering wheel off to try ignition to see if I can find a fault?
    cheers
    vin
  4. Re: Headlights heater wipers indicators and horn not working
    #14
    Nov 2016
    Swindon
    13 Post(s)
    if you can clear the airbag error codes , it is OK to do it.
  5. Re: Headlights heater wipers indicators and horn not working
    #15
    Highlands
    12 Post(s)
    Well I replaced the ignition and all is now well with the car .
    cheers for your help
    vin
  1. Audi a3 wipers and indicators stopped working help!!
    By Malkin1000 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-11-2015, 05:12 PM
  2. wipers, indicators, horn etc not working
    By a4avante in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2015, 11:58 PM
  3. Please Help T5 2006 -- no Indicators, no horn, no wipers.
    By jwhelan in forum The Commercial Range
    Last Post: 04-01-2012, 03:04 PM
  4. Intermitent wipers/indicators/heater fan don't work (1996 1.8 petrol)
    By stewburt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2009, 03:35 PM
  5. Replies: 4
    Last Post: 02-01-2007, 08:05 PM
