Thread: Audi A6 C7 2.0tdi takes ages to get hot ?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
  1. Audi A6 C7 2.0tdi takes ages to get hot ?
    Jan 2016
    Melton Mowbray
    Hi is it normal that my Audi A6 2.0tdi takes ages for the engine to get up to temperature ? The car runs fine and everything seems ok but the temp gauge doesn't move for at least 8 miles of driving and that's only two marks on the gauge and if I pull up with the engine ticking over it doesn't take long for it to drop back down to one mark on the gauge ! I've not had a car before where the temp gauge drops down after pulling over but not turning off the engine ?
  2. Re: Audi A6 C7 2.0tdi takes ages to get hot ?
    Apr 2009
    Surrey
    174 Post(s)
    Common for a diesel. As a design diesels generate very little heat which is why they tend to come with an auxiliary heater to aid the cabin heating system on colder days
  3. Re: Audi A6 C7 2.0tdi takes ages to get hot ?
    Mar 2014
    United Kingdom
    33 Post(s)
    Has the behaviour changed in the time you have owned the car? Did it heat up more quickly in the past? Diesels do take longer than petrol engines to warm up but, once they have reached operating temperature, the gauge should be rock steady, not drop down. Personally, I think the thermostat may be sticking open.
    1 1 0
  4. Re: Audi A6 C7 2.0tdi takes ages to get hot ?
    Tripletrouble Guest
    I was on the M60 a couple of weeks ago in the cold spell. Whilst going through the roadworks I noticed my temp gauge had dropped to 1 bar. This was after a 100 mile drive so maybe they are just efficient.
  5. Re: Audi A6 C7 2.0tdi takes ages to get hot ?
    Jan 2016
    Melton Mowbray
    Quote Originally Posted by wildbore View Post
    I've only had the car 3 weeks so it's always been like this with me
  6. Re: Audi A6 C7 2.0tdi takes ages to get hot ?
    Jan 2016
    Melton Mowbray
    Quote Originally Posted by Tripletrouble View Post
    That's reassuring for me
  7. Re: Audi A6 C7 2.0tdi takes ages to get hot ?
    Pembrokeshire
    22 Post(s)
    should still get to 90 and stay there, even on a really cold day. does the heater blow out piping hot air ? sounds like it needs a new thermostat if the heater is only luke warm after 8 miles.
  8. Re: Audi A6 C7 2.0tdi takes ages to get hot ?
    Mar 2014
    United Kingdom
    33 Post(s)
    Then I suspect you need a new thermostat, too!
    As Zollaf says, modern engines get up to temperature quickly and stay there. The needle should never move, unless you are towing a caravan in the Alps.
  9. Re: Audi A6 C7 2.0tdi takes ages to get hot ?
    Jan 2016
    Melton Mowbray
    The heater gets hot but the engine temp gauge takes ages to go up , are the thermostats easy to fit on these engines ?
  10. Re: Audi A6 C7 2.0tdi takes ages to get hot ?
    Apr 2009
    Surrey
    174 Post(s)
    Quote Originally Posted by craigh9916 View Post
    I see from another post that your car is a 177 engine. I would say in comparing that engine with the 190 (ultra engine) it definitely takes longer to warm up so it may not be anything wrong, but worth checking . You don't say where you bought the car from but if it was from a dealer of any sort then take it back to them as any fault in the first 6 months is there responsibility to fix. If it was from an auction or private sale then it is different
  1. Replies: 1
    Last Post: 04-11-2009, 12:41 PM
  2. Heat takes a while and doesn't get hot
    By taylope1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-10-2009, 11:25 AM
  3. Mk3 Golf TDI ages to start hot or cold!
    By mk1rallycar in forum Chat - Anything with wheels
    Last Post: 26-10-2008, 04:24 PM
  4. Takes ages to start
    By donnadiablo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-08-2008, 10:05 AM
  5. Replies: 0
    Last Post: 15-04-2008, 01:55 PM
