Thread: Thinking about a TDI remap
Results 11 to 20 of 34
  1. Re: Thinking about a TDI remap
    Sep 2015
    Leeds, UK
    I've done a chip on a motorbike ecu but that one was held in with silicone, so it was a matter of cutting the silicone, removing the chip and fitting the new one. It was easy enough but I wouldn't want to solder one in myself. I've read an electrics specialist would do the soldering of the chip quite cheaply.
  2. Re: Thinking about a TDI remap
    May 2012
    Everywhere
    308 Post(s)
    Stick it on a dyno dynamics to find out the truth .
  3. Re: Thinking about a TDI remap
    Jan 2013
    N/A
    Steve, if you click on the "chip only" advert on ebay listing it says to take the chip to an electrician and it can be soldered in "minutes". It probably works, but the thought of taking the ECU box out of my car, asking an electirtian to solder this cheap chip off eBay on to the only ECU box I have is quite risky for me.
    Having said that, plugging an ECU box from eBay without knowing its history is equally questionable.
    As Gazwould mentions, my initial thought of tuning my car is get it tuned (I didn't realise that it's a "chip" job for our AFN engines), where it can be dyno tested pre & post tuning. It's the most secure way to get it tuned but also an expensive option, hence been putting it off as I don't really need it. It's just nice to have more power for fun.
    '11 VW B7 Passat Estate 2.0TDi CFFB (Current)
    '98 VW T4 Transporter 2.5TDi ACV (Previous)
    '99 Audi B5 A4 Avant 1.9TDi AFN (Previous)
  4. Re: Thinking about a TDI remap
    May 2012
    Everywhere
    308 Post(s)
    It's a bit more than that , the engine will idle smoother , be quieter and drive better with more torque comming in earlier and smoother , safer overtaking .
    Keep in a gear longer , better flexibility , less gear changes .
    It's like a newer better more refined engine was fitted .
  5. Re: Thinking about a TDI remap
    Sep 2015
    Leeds, UK
    With mine I only paid £600 for the car. £150 seemed good value for a remap. I'm still going to keep looking around but I don't want to sink loads of money into it. It's false economy to spend hundreds on a car that only cost a few hundred to begin with.
  6. Re: Thinking about a TDI remap
    Sep 2015
    Leeds, UK
  7. Re: Thinking about a TDI remap
    #17
    May 2012
    Everywhere
    308 Post(s)
    Oh God no , they fool a sensor into dumping more fuel in .
  8. Re: Thinking about a TDI remap
    #18
    Sep 2015
    Leeds, UK
    Quote Originally Posted by Gazwould View Post
    Cheers I will avoid those then. I guess my best option is find a 2nd hand chipped ECU or try and find somewhere that sells the chip so I can get it done myself.
  9. Re: Thinking about a TDI remap
    #19
    Sep 2015
    Leeds, UK
    The plot thickens.....
    I have spoken to a few places who all said the chip needs to come out and it'll be around £300. But I also got an email back from a place in Manchester. The first thing he said was "I bet no one's seen your car and they all want to take the chip out"
    He went into a lot of detail. He said there is a switch over point with early A4s. Some can be easily tuned over the OBD port and some need the ECU removed and the chip replaced. He said he would need to see my car to identify which type it is. Also he said if I wanted it, he could do the chip swap version for £250, but he actually advised against having it done, as due to the ECUs capabilities, the results would be nowhear near as good as the normal remap types.
  10. Re: Thinking about a TDI remap
    #20
    May 2012
    Everywhere
    308 Post(s)
    He must know if he's worth his salt what ecu numbers have to be chipped and those that can be flashed .
    Record the number of your ecu and if someone can give you a definite answer go with them .
  1. Thinking of selling my C5 2.5 TDi and buying a C6 2.7 TDi
    By CharlesElliott in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-03-2014, 05:11 PM
  2. 1.8 t sport agu, thinking of remap
    By a3 mark in forum 1.8T - Engine
    Last Post: 26-09-2011, 04:56 PM
  3. Thinking of getting a leon tdi
    By vwnige in forum Leon
    Last Post: 28-07-2011, 07:44 AM
  4. Thinking about Remap, Advice Needed
    By Jakelamotta in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-11-2010, 10:33 AM
  5. thinking of a a6 tdi auto
    By cooljay in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-11-2008, 06:25 PM
