Thread: 2010 Passat - low power
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: 2010 Passat - low power
    #11
    Feb 2016
    Nottingham
    Thanks very much everyone, and for Steve/Crasher for checking the car out so quick. Made me less nervous for the Aberdeen drive. He reckons theres a hole in the actuator diaphragm near the turbo so will be fixed week after next. Thanks again guys!
  2. Re: 2010 Passat - low power
    #12
    Sep 2011
    Orpington Kent
    my 2007 1.9 tdi similar drop in power, I think turbo is either not kicking in or or hesitant at other times. In 2nd gear even without hard throttle, I normally felt the turbo coming in.
    I disconnected the maf while idle no difference. Craigc can you tell me pls in what component is the diaphram your refer to.
    What should I notice with the Maf disconnected?
  3. Re: 2010 Passat - low power
    #13
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by monzo24 View Post
    Diaphragm is the thing that maintains the vacuum in the turbo actuator. If it is split or has a hole the turbo vanes don't move instantly or like they should and you will suffer loss of turbo power.
    Mad Mitch
  4. Re: 2010 Passat - low power
    #14
    Sep 2011
    Orpington Kent
    thanks guys, believe it or not, After I cleaned the maf, then replaced the diesel filter and it solved the problem, even though it was not particularly old.
  1. Knocking/Low Power when Cold - 2010 A3 2.0TDI 6Speed-manual
    By Rich8PA in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-05-2015, 05:50 PM
  2. Please Help Passat 130 Tdi Low power and turbo wooosh.
    By kalas in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-01-2012, 07:14 PM
  3. Passat TDI115 Low Power
    By Morini in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-08-2009, 11:19 PM
  4. Low Power Passat 1.9TDi 115 PD
    By Fizzwizz in forum Archive posts
    Last Post: 21-11-2006, 09:11 PM
  5. passat tdi low power when cold
    By sandy in forum Archive posts
    Last Post: 06-01-2006, 09:28 AM
