Thread: 180 TTC - cruise control?
  1. 180 TTC - cruise control?
    Oct 2007
    I'm thinking of retrofitting cruise control to a 2002 180 TT, and thought that it would have it's own separate control stalk as our B7 A4 Avant. Looking at some photos of one for sale with cruise control, however, there was no sign of an extra stalk underneath the indicator stalk on the left hand side of the steering wheel, as on the A4.
    Is a new indicator stalk required, which includes cruise control?
  2. Re: 180 TTC - cruise control?
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi CC on a Mk 1 TT is on the indicator stalk. It will need replacing with the correct one, there are kits on the web for doing this, and companies who will do it for you. All depends on weather you think you can do it yourself.
  3. Re: 180 TTC - cruise control?
    Jul 2006
    Bloxham, Oxon
    I did this on my 2001 TT last week. New indicator stalk + two pieces of wiring harness + a 5 minute job on VCDS to enable cruise.
    Access is quite limited in the area above the pedals, which makes it tricky. Also you need the dexterity to fit the 4 wire harness into the existing 120 pin ECU plug, the contacts are very small.
    If you're an experienced DIYer, worth having a go yourself. If not, get a specialist to do it.
  1. Replies: 9
    Last Post: 17-02-2016, 06:59 PM
  2. Question steering control module for cruise control
    By doggydoctor in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2012, 11:02 AM
  3. 180 TTC - Cruise Control?
    By urquattro in forum TT - 8N Forum - 1998 - 2006
    Last Post: 23-08-2011, 10:11 PM
  4. Question Cruise control button but no Cruise control
    By ludikris in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-09-2010, 10:34 AM
  5. Instalation of cruise control-does existing control modul support it?
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-03-2009, 09:42 PM
