Thread: AC Button not lighting up. Toggle button not working.
  1. AC Button not lighting up. Toggle button not working.
    Feb 2016
    Swansea
    New Audi Owner so forgive if this is not an issue.
    When I have the climate control in Auto the AC button will not light up; even when pressed (it lights up but as you take your finger off it turns off). So I assume the AC is not running? I've looked at the manual but it says I should be able to toggle it on and off via the button.
    I cannot check if I am getting cold air at the moment as the weather is quite cold.
    Ive attached a video below. Is this a problem I need fixing or am I not doing something. (AUDI 2009 Sport 3.0 TDI)
  2. Re: AC Button not lighting up. Toggle button not working.
    Oct 2005
    Welcome to VWAF
    There are a few Audis, give us a clue which one you have.
  3. Re: AC Button not lighting up. Toggle button not working.
    Feb 2016
    Swansea
    Sorry thought I mentioned it - its a Audi A5 3.0 TDI Sport 2009
  4. Re: AC Button not lighting up. Toggle button not working.
    Oct 2005
    You mentioned all but the model
    Moved to the A5 section where hopefully you'll get the assistance you require.
  5. Re: AC Button not lighting up. Toggle button not working.
    Feb 2016
    Swansea
    Thank you!
  6. Re: AC Button not lighting up. Toggle button not working.
    Aberdeen
    63 Post(s)
    My wife's A4 is going in this Fruday fir the same problem. The only thing I noticed is that her coolant level is below minimum. Might just need a re-gas I suppose.
  1. Replies: 2
    Last Post: 30-10-2014, 02:37 PM
  2. Please Help Handbrake button not working
    By VW Fletch in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-03-2010, 01:30 PM
  3. Question Rns E Mode Button Not Working
    By Andyrhicks in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-01-2009, 08:41 PM
  4. Replies: 0
    Last Post: 02-11-2007, 05:36 PM
  5. 2 button and 3 button fobs / remotes
    By Loofer in forum Archive posts
    Last Post: 07-08-2007, 02:08 PM
