Thread: Vagcom problem faults , where do i start
  1. Vagcom problem faults , where do i start
    Apr 2009
    scotland
    Hi have had a scan done on the car and i have had the faults .
    I have no cooling fans coming on .
    I do there is a broken wire in the door loom , on the ball with that one . any advice would be great , car runs great
    Monday,01,February,2016,15:58:21:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    VIN: WVWZZZ1KZ6W523557 License Plate: 55 plate
    Mileage: 194930km-121123mi Repair Order:
    Chassis Type: 1K (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: WVWZZZ1KZ6W523557 Mileage: 194930km/121123miles
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 R HW: 028 101 222 0
    Component: R4 1,9L EDC 0000SG 7001
    Revision: 12345678 Serial number: VWZ7Z0E2281865
    Coding: 0000071
    Shop #: WSC 01392 785 00200
    VCID: 326BFC43ADDABA8E527-8067
    5 Faults Found:
    18049 - Please check DTC Memory of A/C Controller
    P1641 - 000 -
    Freeze Frame:
    RPM: 798 /min
    Torque: 26.8 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 11000100
    Temperature: 71.1°C
    (no units): 0.0
    17055 - Cylinder 1 Glow Plug Circuit (Q10)
    P0671 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 882 /min
    Torque: 51.2 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 11000100
    Temperature: 9.9°C
    Bin. Bits: 10110000
    17056 - Cylinder 2 Glow Plug Circuit (Q11)
    P0672 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 882 /min
    Torque: 51.2 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 11000100
    Temperature: 9.9°C
    Bin. Bits: 10110000
    17057 - Cylinder 3 Glow Plug Circuit (Q12)
    P0673 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 882 /min
    Torque: 51.2 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 11000100
    Temperature: 9.9°C
    Bin. Bits: 10110000
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
    P0674 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 882 /min
    Torque: 51.2 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 11000100
    Temperature: 9.9°C
    Bin. Bits: 10110000
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0021234
    Shop #: WSC 00792 210 91867
    VCID: 73E539471240F386991-8026
    1 Fault Found:
    00283 - ABS Wheel Speed Sensor; Front Left (G47)
    012 - Electrical Fault in Circuit
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 DF
    Component: Climatic PQ35 090 0505
    Shop #: WSC 00000 000 00000
    VCID: 6BD521274A702B46511-803E
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
    Component: Bordnetz-SG H37 1002
    Revision: 00H37000 Serial number: 00000001962197
    Coding: 00890F2700041800000A00000F000000000859035C
    VCID: 2A5BE423850AF24EEA7-807F
    Subsystem 1 - Part No: 5M0 955 119
    Component: Wischer VW359 012 0402
    Coding: 00065493
    Shop #: WSC 01392
    No fault code found.
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
    Component: 15 AIRBAG VW8 015 2100
    Revision: 03015000 Serial number: 0038ED0G4VKN
    Coding: 0012597
    Shop #: WSC 01373 785 00200
    VCID: 377DCD5746B85FA6659-8062
    Subsystem 1 - Serial number: 6332MSME0A5B055AH
    Subsystem 2 - Serial number: 6342MSME0A674A64J
    Subsystem 3 - Serial number: 6351HSME080F112D7
    Subsystem 4 - Serial number: 6361HSME08070F01%
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AE HW: 1K0 953 549 AE
    Component: Lenksäulenmodul 634 0070
    Coding: 0000002
    VCID: 75E1075F1C34EDB6B75-8020
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 952 B
    Component: KOMBIINSTRUMENT VDD 1012
    Coding: 0003403
    Shop #: WSC 00829 210 52320
    VCID: 29591B2F800CF956E3D-807C
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
    Component: J533 Gateway H56 1642
    Revision: H56 Serial number: 28011400F13254
    Coding: 350003
    Shop #: WSC 12345 123 12345
    VCID: 7CF7127BFF1EBCFEC8B-8029
    1 Fault Found:
    00470 - Combination comfort Databus in Single Wire
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 140
    Mileage: 188232 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:57:28
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1012
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1K0 959 701 E
    Component: Tuersteuergeraet 09 0148
    Coding: 0000052
    Shop #: WSC 01279 785 00200
    VCID: 306FF64BA3D6889E243-8065
    1 Fault Found:
    011 - Open Circuit
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 J
    Component: EPS_ZFLS Kl.5 D04 1606
    VCID: 3365F94752C0B386591-8066
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 AK
    Component: KSG 0401
    Coding: 00C802087F2D8405485F018010CC
    Shop #: WSC 01287 785 00200
    VCID: 79F90B6F302C89D6D3D-802C
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    1 Fault Found:
    011 - Open Circuit
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Component: Tuer-SG 024 2320
    Coding: 0000692
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
    Component: Radio RCD310 016 0049
    Revision: 01000000 Serial number: VWZ1Z2K8568634
    Coding: 0100020002
    Shop #: WSC 00788 648 00255
    VCID: 6BD521278A702B46511-803E
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 F
    Component: Tuer-SG 021 2424
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 F
    Coding: 0000144
    VCID: 3467FA5B57CEB4BE40B-8061
    Address 7D: Aux. Heat Labels: None
    Part No SW: 1K5 963 235 @ HW: 1N0 963 230 E
    Component: PTC-@lement% % 0404
    Revision: 00800050 Serial number: % %
    Shop #: WSC 65536 002 00000
    VCID: 2D51EF3FB4E4E5760F5-8078
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    011 - Open Circuit
  2. Re: Vagcom problem faults , where do i start
    Pembrokeshire
    22 Post(s)
    start by clearing the codes, all codes, then scanning again immediatley, then after a good long drive, to see what comes back. is the car actually getting hot enough for the cooling fans to come on, if its a diesel then almost certainly not.
  3. Re: Vagcom problem faults , where do i start
    Apr 2009
    scotland
    Cheers Zollaf
    I have cleared the codes they just come back up , car never over heats fans never come on now they did work , The coolant will go down after a few months but not empty ,
  1. VAGCOM anyone tried it on a B7 ? (Poxy stop/start)
    By sj_4x4 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 26-09-2011, 11:48 AM
  2. VAGCOM faults on a cutting out A4 B5
    By chrismaher2007 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-01-2010, 05:39 PM
  3. vw crafter no start elec, faults??
    By toma69 in forum The Commercial Range
    Last Post: 12-07-2009, 08:49 PM
  4. VW Golf MK4 - 9 vagcom faults. HELP!
    By chillerz in forum VCDS - General Questions
    Last Post: 27-12-2008, 12:23 PM
  5. vagcom??? Clearing faults.
    By bakili in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-11-2008, 08:03 AM
