Re: Retrofitting memory seats –
12-02-2016,10:26 AM
Fitting full electric seats on the front is quite easy and very doable. Add the memory function and you will need some extra wires. Can wires to the can connector on the A post and an extra wire from the seats to the inside of the front door panel to the memory button. There is additional wiring inside the door panel from the switch to the door module.
The rears are much more complex.... if you want to heat the rear seats then wiring is easy enough but you need the rear controller which is directly controlled by the front. Adding the rear panel means changing the front panel and for full functionality also means changing the heater box behind the dash. 2 Zone and 4 zone have very different heater boxes and changing that unit is a dash out, air con de-gas etc A major pita job.
Oh and dont forget the CP
RS6 Performance Ascari Blue, Carbon Ceramics Brakes and lots more.
A6 BiTdi Avant MTM
Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds,High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
