Thread: Retrofitting memory seats
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Retrofitting memory seats
    Aug 2009
    cheshire
    6 Post(s)
    98 Post(s)
    Is the 10A fuse the original one that was in there when you had power lumbar only? If so then up the fuse to a 15A one as the seat is drawing a little bit more current at the end stops as it trying that 'bit'harder. You wont burn the wiring unless you are moving seats non stop for hours
    RS6 Performance Ascari Blue, Carbon Ceramics Brakes and lots more.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds,High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  2. Re: Retrofitting memory seats
    Dec 2015
    Essex
    Quote Originally Posted by morski View Post
    Thanks for the quick response - yes, the original fuse was 10A and is specified as such per the owner's manual. I'll up it to 15A and report back.
  3. Re: Retrofitting memory seats
    Dec 2015
    Essex
    Fitted the 15A fuse today, all works perfectly! Thanks for your help.
    0 2 0
  4. Re: Retrofitting memory seats
    Dec 2015
    Essex
    Hmm, well a few weeks in now and the 15A fuse blows intermittently. Not always at the end of the motor's range, not really consistent on when it does it.
    Am I safe to go up to 20A fuse, or is that risking burning out the wiring?
    Should I just stick with 15A, bulk buy them and just keep replacing it every week or so?
  5. Re: Retrofitting memory seats
    Jan 2019
    Brighton
    Hi Morski/youngsyr,
    I'm upgrading my seats too, but can only find the fuse for the driver side lumbar support in my manual.
    Did you have to change the fuse on the passenger side too?
    Many thanks!
  6. Re: Retrofitting memory seats
    Aug 2009
    cheshire
    6 Post(s)
    98 Post(s)
    iirc both the passenger side and drivers side lumbar fuse is on the drivers side fuse panel. Its been a good while since i did this retrofit... I'd have to look into the manual more later if you still cant find it
    A6 BiTdi Avant MTM
  7. Re: Retrofitting memory seats
    #17
    Dec 2015
    Essex
    I've just retrofitted a fully electric adjustment heated seat in place of my manual adjustment (electric lumbar) heated seat and initially it worked perfectly.
    However, my wife took the car and reported back that the seat didn't work from the first moment she tried it. I've checked the fuse (position C10, red fuse box on door side of the dashboard) and it's a 5A, and it hasn't blown. The lumbar adjustment also still works, but not the height and tilt buttons.
    This has me stumped as I expected it to be the blown 5A fuse?
    Are there any other fuses I need to check - strange that the lumbar support works but not the rest of the adjustment.
    I fitted the seats this afternoon and played around with all the adjustments and heating - all worked perfectly?
  8. Re: Retrofitting memory seats
    #18
    Dec 2015
    Essex
    OK, so currently the seat is stuck in the car, covering the rear two mounting bolts so I can't get the seat out, which is my first priority. I can worry about getting it to work later. I need an adjustable seat as the car is shared.
    I've managed to get access to the seat adjustment switch wiring and a wiring diagram.
    I'm hoping I can just apply 12v to the Green/Blue wire (height adjustment) and it will raise the seat - giving me access to the rear bolts under the seat to remove the seat.
    Can anyone more auto-electrically minded please tell me if this will work?
  1. memory seats
    By bops6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-12-2015, 01:08 AM
  2. Heated seats memory
    By Rsheen in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-01-2013, 02:45 PM
  3. Help with Memory seats
    By daboogie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-12-2012, 02:12 PM
  4. Please Help A4 Cab Memory seats
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-06-2009, 08:16 PM
  5. memory seats retrofit?
    By dansansome in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-03-2009, 08:36 PM
