Thread: help with fault code
Results 1 to 8 of 8
  1. Help with fault codes Battery draining
    Nov 2013
    leicester
    i have the following fault codes, the problem is my battery is draining but i dont know why if someone can help out be much appreciated. i have attached a photo of the battery condition the battery was change by audi in Dec 2013. for a 2 year old battery i think the battery condition is poor. the below battery status was taken when the car was running.
    Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 B HW: 03L 906 022 B
    Component: R4 2,0L EDC H01 3210
    Revision: --H01---
    Coding: 0104002C18072018
    Shop #: WSC 00640 210 90997
    ASAM Dataset: EV_ECM20TDI03L906022B A01014
    ROD: EV_ECM20TDI03L906022B.rod
    VCID: 24470A1B2F2E243ED0B-8071
    2 Faults Found:
    7859 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 00 [032] - Implausible Signal
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 151352 km
    Date: 2016.01.15
    Time: 18:07:26
    4985 - Cylinder 2 Glow Plug Circuit (Q11)
    P0672 00 [109] - Electrical Fault
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 150195 km
    Date: 2015.11.20
    Time: 05:42:21
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
    Component: KOMBIINSTR. H14 0216
    Revision: 00100000 Serial number: 7BY30DC28
    Coding: 2F3D080002003600010001
    Shop #: WSC 06325 123 12345
    VCID: 3169F34F68DC81962BD-8064
    1 Fault Found:
    01298 - Instrument Cluster Lamp Test
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 191
    Mileage: 151049 km
    Time Indication: 0
    Date: 2015.12.23
    Time: 14:35:36
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 D HW: 8T0 907 468 D
    Component: GW-BEM 5CAN H04 0084
    Revision: GA801030 Serial number: 3000G081258229
    Coding: 000003
    Shop #: WSC 78641 024 535012
    VCID: 428BAC83DD7A0A0EC27-8017
    Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H03 0150
    1 Fault Found:
    03041 - Energy Management Active
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 39
    Reset counter: 212
    Mileage: 149301 km
    Time Indication: 0
    Date: 2015.10.30
    Time: 16:17:28
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
    Component: TSG FA H10 0170
    Revision: Serial number: 0000006879852
    Coding: 011002204001410001
    Shop #: WSC 06325 000 00000
    VCID: 408FA68BD376181ED43-8015
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 213
    Reset counter: 224
    Mileage: 150152 km
    Time Indication: 0
    Date: 2015.11.17
    Time: 10:20:00
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
    Component: TSG BF H10 0170
    Revision: Serial number: 0000006836449
    Coding: 011002205401410001
    VCID: 3F8DA577AE8867E6AD9-806A
    1 Fault Found:
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 99
    Reset counter: 184
    Mileage: 149107 km
    Time Indication: 0
    Date: 2015.10.28
    Time: 08:02:16
    thanks
  2. Re: Help with fault codes Battery draining
    Nov 2013
    Cumbria
    Is that with the engine running ?
    Audi A6 C7 Avant - quattro, black edition sline - 3.0 BiTDi
    Audi A3 8PA - quattro, black edition sline - 2.0T
    Audi A4 B8 Avant SLine - 3.2 V6 Quattro - now sold
    Audi A3 8P - 2.0T Quattro - sold
    Audi A4 B7 Avant - 2.0T - heap of junk, now gone!
  3. Re: Help with fault codes Battery draining
    Nov 2013
    leicester
    yeap the engine is running
  4. Re: Help with fault codes Battery draining
    Nov 2013
    Cumbria
    Looks like your alternator is on its way out and isn't charging battery sufficiently, hence the drained battery. My supply is 14.7v ish when engine running.
  5. Re: Help with fault codes Battery draining
    Dec 2007
    8 Post(s)
    One thing to check is the heavy altenator cable for condition at terminal, I have seen a case where this caused loss of charge.
  6. Re: Help with fault codes Battery draining
    Nov 2013
    leicester
    thanks for the reply ill have the alternator looked at, any guess's on the other fault codes
    thanks
  7. Re: Help with fault codes Battery draining
    Nov 2013
    Cumbria
    Quote Originally Posted by danny851 View Post
    thanks
    They are all related to the lack of juice from the battery apart from those under Engine.
    1. Intake manifold - some say you can clean it, some say replace. I think it's quite an expensive part.
    2. Glow plug cylinder 2 needs replacing.
  8. Re: Help with fault codes Battery draining
    Nov 2013
    leicester
    Quote Originally Posted by b206 View Post
    Thanks mate ill have to get the intake manifold looked
  1. Dreaded ESP Fault DIS warning and G201 fault code
    By Daz6546 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-09-2015, 01:53 PM
  2. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  3. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
