Thread: Central locking question
  1. Central locking question
    Sep 2009
    northumberland
    Apologies if this has already been covered, I've seen similar problems posted on here but non are quite the same as far I can see.
    My drivers door has stopped unlocking via the key fob, it locks but wont unlock. However it will lock and unlock with the key?
    I'm guessing its going to be a new lock mechanism but any advice would be appreciated.
    2008 A6 avant 2.7 fwd multitronic >100k miles!
  2. Re: Central locking question
    May 2014
    Darlington
    78 Post(s)
    Covered lots of times, the door won't open from the outside door handle but will open from the inside handle.. You will need a new mechanism, it's a common fault and you may also find the passenger side stops working at some point soon with the same fault.
  3. Re: Central locking question
    Sep 2009
    northumberland
    The door opens fine from the outside using the key, locks and unlocks no problem. It just won't unlock using the key fob?
  4. Re: Central locking question
    Dec 2007
    8 Post(s)
    Don't know, but do the other doors unlock with fob,or is it confined to drivers door only not unlocking.
  5. Re: Central locking question
    May 2014
    Darlington
    78 Post(s)
    Press the unlock button on the remote, if you cannot open the door using the external handle, but you can using the internal, then it's the common fault that most A6's appear to suffer.
  6. Re: Central locking question
    Sep 2009
    northumberland
    Even though it locks and unlocks with the key?
    It was buzzing/chattering when locking and unlocking using the remote a few months ago but then it stopped and has been fine until it has now packed in altogether with the remote.
    Looks like it could be a new lock then. Cant really complain its done 108k now and this is the first thing thats failed!
  7. Re: Central locking question
    Nov 2012
    Somerset UK
    Mine usually only does it when it's damp, even then a few scans/clears with VCDS usually see's it alright for a few months
    I mostly just open the rear drivers side door and then open the front door manually...not particularly graceful but works for me!
    1 1 0
  1. CCM and central locking question
    By Brudder in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-03-2010, 08:37 PM
  2. Central locking question
    By stig414 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-11-2009, 09:09 PM
  3. Central locking question
    By Stuart W in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2009, 09:43 PM
  4. Polo Central Locking Question
    By vwpolo1967 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-06-2009, 01:38 PM
  5. Central Locking key question
    By Dave40 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2007, 07:27 PM
