Thread: problem with vibration when braking
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: problem with vibration when braking
    Dec 2005
    As I mentioned before. Two weeks ago I have changed front tyres and it was vibrating before and still is.. How to check if this is are brakes and which one front or rear?
  2. Re: problem with vibration when braking
    Dec 2007
    8 Post(s)
    If you have to fit new front pads and discs,ensure that the mating hubs are cleaned spotlessly before fitting new discs,or you may have to repeat job in a short time.
    Check for wear in front suspension before fitting brake units
    It seems from what you describe more likely to be front brakes or suspension problem
  3. Re: problem with vibration when braking
    Dec 2005
    Wheels are fully balanced as I changed them two weeks ago and today. Vibration was before change and after.
  4. Re: problem with vibration when braking
    Mar 2014
    Edinburgh
    235 Post(s)
    Likely a bush or a ball joint if it was happening before your new tyres.
  5. Re: problem with vibration when braking
    Jun 2015
    Europe
    Brake discs 100%. Even at 30 k after fitting the new discs if you travel on motorway and are driving at 90 mph and reduce to 40 -50 mph rapidly and then return to 90 mph the metal on the discs unless they are OEM ( original Audi ones) are prone to warping. If this is part of your driving behaviour and is repeated then the discs will not survive without warping. In basics the discs heat up very quickly and get extremely hot and then cool quite rapidly as you simply continue on your motorway journey resulting in deformation and warping. Happened to me years ago so i have practical experience.
    I also have a friend that had an RS4 who took it to a track and same conditions high speed rapid braking + super tempratures and then rapid cooling as it went onto the next straight. Discs become warped. He went to Audi and told them the brakes were vibrating. Audi inspected the brakes and could see the tell tales signs of overheating of metal and the told him to "P" off saying to him you've been racing this thing !!
    Heat tint colour chart
    The table below represents the temper colours that are likely to form on stainless steel type 1.4301 (AISI 304) if heated in air.
    THIS INFORMATION MUST BE USED WITH CARE WHEN INTREPETING THE HINT TINT COLOURS OBSERVED ON STAINLESS STEEL SURFACES AS THE HEATING CONDITIONS ARE NOT SPECIFIED.
    Colour Formed Approx Temperature C
    pale yellow 290
    straw yellow 340
    dark yellow 370
    brown 390
    purple brown 420
    dark purple 450
    blue 540
    dark blue 600
  6. Re: problem with vibration when braking
    Jan 2016
    Peterborough
    Sounds like the discs too me, when they get excessively worn they can warp and cause a judder under braking, if it's felt through the steering wheel as apposed to the body of the car it's more than likely the front discs
  7. Re: problem with vibration when braking
    #17
    Feb 2012
    Essex, innit.
    The most likely cause of this is if you park outside and are getting a film of rust on the discs. The area behind the pads doesn't rust and you end up with very slight differences in the thickness of the discs, once the rust has been wiped off. It should go after a couple of big breaking actions as the pads will re-face the discs.
    If it doesn't go, you can get the discs re-faced with a grinding machine. The wheels need to come off but the machine does the discs with them still on the car. If they are OE discs and are otherwise perfect, it's worth trying this before replacing them.
    A6 Bi Turbo (320PS) Black Edition, Techno pack, Matrix lights, heavy right shoe. Sept 2015.
  1. Strange Vibration Under Braking
    By audi-nutz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2014, 10:47 AM
  2. Passat braking vibration and knocking
    By samcaravelle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2009, 08:04 AM
  3. Braking vibration but not discs.
    By Little Old Me in forum Touran - Sharan - Caravelle
    Last Post: 15-12-2008, 11:43 AM
  4. Courtesy light and vibration on braking
    By Dabj in forum Golf MK4 - 1999 - 2004
    Last Post: 28-11-2007, 10:50 PM
  5. Golf mk3 GTi steering vibration when braking.
    By johnpatmos in forum Golf MK3 - 1993 - 1999
    Last Post: 12-08-2007, 10:39 PM
