Thread: Oil passing turbo oil seals into exhaust
Results 1 to 10 of 19
  1. Oil passing turbo oil seals into exhaust
    Apr 2012
    wigan
    Audi A4 tdi 2.0
    Has anyone had an issue with oil pressure causing oil to be forced past the turbo oil seals into the exhaust.any info would be appreciated
    thanks
  2. Re: Oil passing turbo oil seals into exhaust
    Pembrokeshire
    22 Post(s)
    generally this happens when the oil seals are worn out and your turbo needs an overhaul.
  3. Re: Oil passing turbo oil seals into exhaust
    Apr 2012
    wigan
    My turbo has been off and tested at ac turbos,it has also had a full overhaul
  4. Re: Oil passing turbo oil seals into exhaust
    Pembrokeshire
    22 Post(s)
    and still leaks oil ?
  5. Re: Oil passing turbo oil seals into exhaust
    Apr 2012
    wigan
    Yes the guy said it sounds like crankcase oil pressure.he tested my turbo on the machine and it never passed oil so he said something is forcing it past
  6. Re: Oil passing turbo oil seals into exhaust
    Pembrokeshire
    22 Post(s)
    nest job is to rig up an oil pressure tester and see what you are getting with the engine running. only 2 things i can think of, the pressure relief valve on the pump is jammed or , and its a long shot, there may be a restrictor in the oil feed pipe to the turbo, by way of a smaller hole in one of the banjo unions, and this is missing. to be fair though i have only ever known a turbo to leak because its broken. too much oil pressure , which is a very very rare thing to have, usually results in oil being forced out of every orifice it can find, oil seals, cam cover. now i don't know of ac turbos, but if your car came into my garage, even if you have had the turbo tested, i would still send it to turbo technics and get them to give it the once over. yes, i have known plenty of turbos to dump oil straight in to the exhaust, often on newish cars. nissan x trails did it a lot circa 2004.
  7. Re: Oil passing turbo oil seals into exhaust
    Apr 2012
    wigan
    My turbo is practically brand
    new.ok I will do some
    research on pressure relief valve.thanks for your time
  8. Re: Oil passing turbo oil seals into exhaust
    Oct 2015
    GB
    Are with with zolaff
    Sent from my SM-A300FU using Tapatalk
  9. Re: Oil passing turbo oil seals into exhaust
    Apr 2012
    wigan
    oil passing turbo seals into exhaust creating smoke was back pressure from a piston that had gone bad.wounded is not the word ������
  10. Re: Oil passing turbo oil seals into exhaust
    Feb 2016
    Chelmsford essex
    Hi been under my golf mk4 tdi 115bhp today to do other jobs and noticed a oily flexi pipe the turbos still boosting up ok and still good mpg any ideas guys and girls would be good the head gasket was done 5000 miles ago just seems like one thing after another
  1. Replies: 10
    Last Post: 29-04-2017, 06:25 PM
  2. Question What oil seals do i need?
    By Henry2202 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-07-2013, 06:30 PM
  3. Leaking oil thru turbo seals
    By Wilts in forum 1.8T - Engine
    Last Post: 23-09-2012, 09:04 PM
  4. Turbo oil seals gone
    By mikea31.820vt in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-11-2010, 08:41 AM
  5. Oil in the exhaust, white smoke, even with new turbo
    By Uruk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2008, 10:34 AM
