Thread: Engine oil leak
  1. Engine oil leak
    Jan 2016
    leicester
    Hi I'm new to the Phaeton and have just purchased a 54 plate V10 the owner told me it has a very small leak approx 1 ltr every 8000 miles and does not spill on to the drive well what a load of crap that was now found it to be the combi pump leaking has anyone done one of these as there is only one bolt that we cannot get too and don't want this to tarnish the owning experience.
    cheers neil
  2. Re: Engine oil leak
    108 Post(s)
    1816 Post(s)
    Those are probably the most difficult engine I have ever worked on, I would rather change the plugs on a XJ12 HE blindfolded with one hand tied behind my back than get deep into one of those, utter nightmares. Have you removed the inlet manifold?
  3. Re: Engine oil leak
    Jan 2016
    leicester
    Hi Crasher yes mate had to do that to get to the pump im just trying to think of a way to get to this last allan key bolt as its right up to the bulk head ??? !!!!.
    thanks for your reply Neil.
  4. Re: Engine oil leak
    108 Post(s)
    1816 Post(s)
    I use a very short 5-mm hex key with a 10-mm drive fitting and a 10-mm ratchet spanner. The situation is much the same with a Toerag 5 cylinder.
  5. Re: Engine oil leak
    Jan 2016
    leicester
    Thanks for your help Crasher.
    Neil
  6. Re: Engine oil leak
    Sep 2016
    Sussex UK
    Hi merce55. Did you get your pump problem fixed? Cheers H
  1. Please Help Oil Leak From Side Of Engine
    By MAF72 in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2013, 04:50 PM
  2. Oil leak from rear of engine (2.8 ACK Engine)
    By stoocake in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-01-2011, 09:35 PM
  3. Please Help Engine oil leak
    By jonjosar in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-01-2011, 10:37 PM
  4. Please Help Oil leak on top of engine
    By skulz768 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-05-2009, 10:50 PM
  5. Engine oil leak
    By tel7448 in forum Passat - Archive Topics
    Last Post: 01-04-2007, 10:30 AM
