Thread: VCDS Screen size adjustment
  1. VCDS Screen size adjustment
    Jul 2013
    76 Post(s)
    This is for roy clark
    find the VCDS folder on your C Drive should be Ross-Tech/VCDS then open the VCDS.CFG file with Notepad and then change the size to 10 (default is 10).
    If you want it full screen then you adjust it to fit dependant on your screen size, increase the number to make it bigger.
    Dan
    2009/2010 2.0 TDIe SE
  2. Re: VCDS Screen size adjustment
    46 Post(s)
    Third thread on the same subject.
    The original thread has been updated
    Screen too big
  1. Switching off automatic mmi screen opening using VCDS
    By jbmercapple in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 14-12-2015, 03:35 PM
  2. A3 190hp . What wheel size, what tyres size would you buy
    By MR2BIG in forum Wheels and Tyres
    Last Post: 08-09-2015, 09:44 PM
  3. Screen size
    By A1287210 in forum A7 - S7
    Last Post: 23-10-2013, 12:34 PM
  4. Washer jets spary on rear screen not front screen
    By strongbow128 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-03-2011, 08:25 PM
  5. RCD 510 Screen Size
    By dataconn in forum Golf MK6 - 2009 - 2013
    Last Post: 27-05-2010, 10:39 PM
