Thread: A6 Allroad 2007 sitting on bump stops showing codes 02646 & 00453
  1. A6 Allroad 2007 sitting on bump stops showing codes 02646 & 00453
    Jan 2016
    Cork
    If anybody can give me details on the above codes would really appreciate it.
    I have picked up a compressor repair kit from bagpipingandy but the guy who is going to fit it for ran the diagnostics & asked me to check the codes.
    I ran a search of the threads but got nothing
  2. Re: A6 Allroad 2007 sitting on bump stops showing codes 02646 & 00453
    Jan 2011
    Stafford, UK
    Quote Originally Posted by Andy Bonser View Post
    00453 - The Audi TT Forum :: View topic - 00453 - Function limitation due to Over-temperature haldex t
    02646 - VAG Error Code: 02646
    Fault Location:
    Plausibility of Level Control System - Implausible Signal - Intermittent
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Wiring/Connector(s).
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  3. Re: A6 Allroad 2007 sitting on bump stops showing codes 02646 & 00453
    Jan 2016
    Cork
    Thanks for the reply Roy.
    I have had problems with the air suspension for a while, being sluggish to get up to each level etc, that is why I bought bagpipingandy's kit thinking it would be the compressor piston ring that was worn so I am hoping that will cure the 02646 problem.
    00453 is a worry, the car is an auto so this is a problem with the transmission fluid temp sensor??? or are we in to a code with a deeper meaning?
    A
  4. Re: A6 Allroad 2007 sitting on bump stops showing codes 02646 & 00453
    Jan 2016
    Cork
    Just as a follow on from my original post.
    The guys looking at the car have said that when it starts up they get a solenoid clicking in but the compressor does not run.
    They have the compressor on the bench & give it a direct feed & it does run but it seems to be drawing high current.
    They seem to think it is a control module of some description & want to send it on to a guy who deals in electrical problems only.
    Anybody got an idea if these guys are on the right track or are they missing something?
    They seem like good guys & are recommended by a couple of people we know so I am sure they are giving it their best shot.
    Any advice would be greatly received.
    A
  1. bump stops on 2001 passat saloon
    By smithy602179 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-10-2011, 10:13 AM
  2. Question Rear bump stops.
    By charliebrown in forum Bora - 1998 - 2005
    Last Post: 14-09-2011, 12:31 PM
  3. Touran front bump stops
    By maf def in forum Touran - Sharan - Caravelle
    Last Post: 22-09-2010, 09:10 PM
  4. Question Lowering - Bump Stops
    By ming in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-03-2010, 01:13 PM
  5. I need new bump stops (rear)
    By ihs61 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-02-2010, 09:21 PM
