Thread: Air suspension rebuilds ?
  1. Wink Air suspension rebuilds ?
    Jul 2012
    Kent
    Hi folks, after a bit of a dispute with a known re-conditioner, I've decided to embark on the rebuild myself, and to my surprise ( after having worked for decades on normal spring steel suspensions ), the air ride system is easy to repair !
    VW charge I think, at last check, about £1000 per shock & will not reuse the old damper...
    Re-conditioners charge usually a whopping £600 per side.
    After stripping my old unit down, it's evident that the dampers never get touched & the only replaceable part is the airbag assembly, which interestingly comes anyway from China.
    I'm in the process of negotiating a set of front bags ( as my old RHS front will be re-sold as rebuilt on the web later, pretty much for what it cost me ).
    Basically, for about £200 you can rebuild your own air struts, so get out & don't be afraid to have a go yourself, taking the air spring off the car, takes only 2hrs at most & the srtip down of the damper assembly is about 40mins with basic tools !
    HTH, pics will follow of course !
    2007 3.0 tdi S-Line Avant.
    20 inch RS alloys, F/r park distance,S-Line leather, colour coded All road side skirts, Xenons
    Luv it !
  2. Re: Air suspension rebuilds ?
    Jul 2012
    Kent
    couple of quick pics of the stripped & prepped strut
    and one of the old airbag that has a small tear in the sleeve ( soon to be binned ! )
    for WIW for you chaps, the supplier has agreed a price of £150 per bag, although it'll take a few days shipping.
    Much cheaper than the horrendous £600 prices on the web from other suspension rebuilders ( whom use the same suppliers ! most probably ! )
    Hope this helps save some of you some pennies.
    Luv it !
  3. Re: Air suspension rebuilds ?
    Jan 2016
    New Zealand
    Hey,
    Have you had any luck? Any advise would be much appreciated.
    Cheers.
  4. Re: Air suspension rebuilds ?
    Jul 2012
    Kent
    Yes mate, all sorted.
    I fixed my OEM strut & have found the suppliers in china...
    £160 inc' customs delivered to the UK from HK.
    30 mins to strip & swap over the airbag assembly.
    Even basic leaks can be repaired for the sake of a few "O" rings....
    If you can remove the strut yourself from the car ( which is about 2hrs work, an hour if I don't stop for a cuppa ), then you'll save wasting your money with a futile visit to the *******. And don't delive any rubbish about the shocks needing new controllers... they DON'T.
    There are a few Uk rebuilders... I'd avoid Aerosus, they were crappy & the workmanship was awful.
    I'll always rebuild myself from now on.... so easy !
    Regards.
    Luv it !
  1. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  2. air suspension
    By teamorange in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-11-2014, 09:04 PM
  3. need some help please.... - Air suspension
    By cooper86 in forum A8 - S8 - V8
    Last Post: 04-02-2012, 08:57 PM
  4. Attention A8 air suspension
    By richard.billing in forum A8 - S8 - V8
    Last Post: 05-09-2009, 10:40 PM
  5. Engine rebuilds????
    By swompy in forum Golf MK3 - 1993 - 1999
    Last Post: 25-09-2008, 03:45 PM
