Thread: Folding mirrors
Results 11 to 20 of 21
  1. Re: Folding mirrors
    Mar 2010
    Manchester
    Tried a different module and no errors raised this time. All door functions work and mirrors fold with switch and when locking car. Only issue is that mirrors auto fold out approx 15 seconds after engine start.
  2. Re: Folding mirrors
    46 Post(s)
    Which ones are you using now?
    Thats not an issue, thats how they're supposed to work.
  3. Re: Folding mirrors
    Mar 2010
    Manchester
    Code P post 2012 module. Pretty sure it shouldn't be delayed,
  4. Re: Folding mirrors
    May 2014
    Huddersfield
    Quote Originally Posted by Oracle View Post
    Hi, I'm thinking of doing this mod. Could you give me the list of part numbers used and also the approximate cost of the complete mod? Thanks, Chris
  5. Re: Folding mirrors
    Mar 2010
    Manchester
    Hi, parts listed are for facelift 2012> A4.
    You obviously need new mirror bases (8K2 857 409 AJ and 8K2 857 410 AH - RHD only)
    New mirror switch, didn’t note the part number.
    New switch surround 8K2 867 172 E (black) and New optic 8T0 919 173 A
    I reused my original glass but factory fit would use dimming glass. (Mirror bases have plug for dimming)
    In all approx. £470 with switch and controllers from ebay.
    Rebuilding the mirrors was fiddly as it takes a while to release all the clips without breaking them.
    The only problem was the door controllers; I had to change mine as they weren’t highline. Highline support mirror fold but normal ones don’t. After some research I discovered there are many versions and many manufacturers of these controllers for an A4/A5. Pre 2012 controllers don’t work with Post 2012 cars it seems.
    In my case I had Q controllers and I replaced them with P.
    Coding was straight forward, initially they didn’t fold out straight away but after playing with the coding they now fold out as soon as ignition is started. Also passenger mirror dip now works properly as before it always raised back slightly too high.
  6. Re: Folding mirrors
    Feb 2016
    Hi - I am a newbe nd hope I am in the correct forum area! Also I am not very technical .
    I had an auto electrician specialising in Audi vehicles retro fit electric folding mirrors on my 2013 petrol Audi A4 allroad Quattro to replace existing electrically heated factory fitted mirrors so I could get the car in the garage without fouling the mirrors . Also I often have to use narrow country roads where the folding facility is very useful to me to give me more clearance from passing vehicles. My auto electrician was able to fit the mirrors and activate the folding feature with the fob when the vehicle is locked and open when the car is started. However he cannot activate either the manual override or the reverse tilt feature( I understand this is only available on some models). Do I have to replace the existing driver door control switch as well . The auto electrician does not think so or does not know. I saw a You Tube video when researching the topic and it shows the switch going from the 12 O clock position to the S6 O clock position Edith a light coming on just below the switch. My switch will not go beyond 1 O clock. Any suggestions or help would be appreciated to solve my problem .
  7. Re: Folding mirrors
    #17
    46 Post(s)
    You need the new switch, trim surround and fibre optic lighting ring for the switch to enable the folding-on-demand option.
  8. Re: Folding mirrors
    #18
    Mar 2010
    Manchester
    Yes, new switch and surround. To enable mirror dip I setup the passenger door controller like so.
  9. Re: Folding mirrors
    #19
    Feb 2016
    Hi Thanks for the information.
    My local Audi are unable to find the part number for this driver door switch but are able to get the surround with the manual on demand symbol at the six o' clock position.
    They had no new ideas other than agreeing that I needed a new switch which would turn to six 0' clock.
    Does any one know the part number or where I might be able to source this switch. The Vehicle is an AUDI A$ all road quattro 2013 model
  10. Re: Folding mirrors
    #20
    46 Post(s)
    8K0 959 565 E (WEP)
    Switch
    8T0 919 173 A
    Lighting trim for switch
  1. Question Folding mirrors
    By bingodingo in forum A7 - S7
    Last Post: 12-08-2014, 10:40 AM
  2. Folding Mirrors
    By Chris-h in forum Golf MK6 - 2009 - 2013
    Last Post: 16-06-2010, 04:05 PM
  3. Folding Mirrors
    By stevo870 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-01-2010, 11:16 PM
  4. Folding mirrors
    By B5Jon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-09-2008, 10:46 PM
  5. 04 A8 Folding Mirrors
    By J7KED in forum A8 - S8 - V8
    Last Post: 03-02-2008, 06:18 PM
