Thread: Parking Brake Malfunction, ESP, EPB, ABS - Car Wont Start - SO MANY FAULT CODES!!
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. Re: Parking Brake Malfunction, ESP, EPB, ABS - Car Wont Start - SO MANY FAULT CODES!!
    #21
    Jul 2018
    Wigan, UK
    Quote Originally Posted by Graceland77 View Post
    Hi mate, car still working like it should with no errors coming on at all, its a relay underneath the ecu, it’s defo 614 if your a6 is a 2007.
    From what I remember If you take wiper arms off, then black plastic cover, ecu metal black casing top right, Audi opened that for me so don’t know how they did it, ecu inside, lift up and there are a few relays underneath, just swap the 614 out with 644 from parts shop, still mega thanks to the guy or gal who found this, we salute you!
    Thankyou for your swift reply. I'm currently borrowing my Dads 2009 Peugeot 308 SW Sport and I really want to stop driving it. Hopefully I can make tomorrow that day now.
  2. Re: Parking Brake Malfunction, ESP, EPB, ABS - Car Wont Start - SO MANY FAULT CODES!!
    #22
    Jul 2018
    Wigan, UK
    Worked! Just to pay it forward as mentioned if anyone does find this thread again. There is no 614 relay on the diagram the Parts Dept use. They'll not have a clue. Guaranteed it's under the ECU though. Dead easy to remove. Take off the trim running along the cover and then remove the plenum cover. On the passenger side remove max 5 screws all torx bit. Lift the cover and it'll stare you in the face. Really simply op and under 15 min job getting the replacement relay not withstanding.
    Attached is the part number for the latest 644 relay needed.
    https://imgur.com/a/wgdx7hE
  1. passat b6 parking brake abs esp fault
    By bolts85 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-10-2015, 08:30 PM
  2. ABS/ESP Parking Brake fault, please refuel??
    By Nickp88 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-04-2015, 05:29 PM
  3. car wont start and no fault codes
    By mav84 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-01-2012, 09:56 AM
  4. abs/esp and epb malfunction
    By darkomega in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-01-2012, 11:36 AM
  5. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
