Thread: Replacement Front Fog bulbs
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
  1. Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    I've just got my GT with LEDs (standard) and think the front fog bulbs really spoil the look. If it didn't use them for the cornering of every time you reverse, I wouldn't bother, but I want to change them to LEDs to get the same white look. Has anyone done this? Wondered how hard it was to get access and also if it would create fault lights if I did?
  2. Re: Replacement Front Fog bulbs
    Aug 2007
    Hampshire
    I was wondering about that as well Technik. I have the level 2 LED headlights and thought the fog lights looked strange being a more yellow light. Anyone know if it's easy to change the bulbs or make them LEDs?
  3. Re: Replacement Front Fog bulbs
    Apr 2007
    Lancashire
    You do know that using fog lights in clear conditions irritates other drivers and marks you out as a muppet, don't you?
  4. Re: Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    Quote Originally Posted by BenR View Post
    Oh, silly me for having a car that uses the fog lights as the static cornering function. I don't think the issue I have with the fog lights being yellow has anything to do with me wanting to drive around like a furry puppet, it was just a question about if the bulbs could be changed.
  5. Re: Replacement Front Fog bulbs
    Aug 2007
    Hampshire
    Same here Muppet. I was only asking about changing the bulbs
  6. Re: Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    Easier than I thought!
  7. Re: Replacement Front Fog bulbs
    Aug 2007
    Hampshire
    Thanks Technik. Where did you find the images?
  8. Re: Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    Quote Originally Posted by P Adams View Post
    From the online manual. Going to check it out today if I get a chance.
  9. Re: Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    Might not be as simple. Mine seems to have a Torx screw in there which I haven't got a thin enough version to get through the hole. ��
  10. Re: Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    Ok - here's a quick guide after I managed to change them in between the rain!
    1.jpgThe hole on the front cover is to access an adjuster screw - not to remove the cover!
    2.jpgHidden on the inside of the cover under the fin is a screw hole....
    3.jpgThe screw can be removed with a flat head or a Torx 15
    4.jpgAfter removing the screw - very gently prise the cover forward - you can use the hook tool from the toolkit, but I wouldn't put it in the front hole as suggested in the manual - prise top and bottom above and below the screw hole you have just removed the screw from.
    5.jpgThe cover is clipped in top and bottom along it's length and finally slots behind the main trim with these two lugs.
    __________________________________________________ ___________
    Did have A4 Technik 170. Now got Passat B8 150 GT Indium Grey with LEDs.
    0 2 0
  1. Question Front Fog Light Replacement
    By Dook in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-11-2013, 10:53 AM
  2. Front fog light bulbs
    By Brawn in forum Touran - Sharan - Caravelle
    Last Post: 18-12-2011, 11:42 PM
  3. change front fog lamp bulbs
    By getjasonroberts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-01-2011, 05:03 PM
  4. Replacing fog light bulbs from the front?
    By allya in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-12-2009, 09:17 PM
  5. Front fog Lamp replacement
    By sathound in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-12-2008, 11:57 AM
