Thread: Replacement Front Fog bulbs
Results 11 to 20 of 36
  1. Re: Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    6.jpgWhen you've removed the cover, you will see two screws top and bottom of the light
    7.jpgRemove these with a flat head screwdriver
    8.jpgand the light assembly swings out.
    9.jpgIt is retained by two lug similar to the cover. The bulbs can be easily removed now.
    10.jpgOn the left is a Canbus LED - H8 Cree bulb from Autobulbs Direct (£30 a pair) H8 Twenty20 Cree LED 12V Canbus Foglight Bulb
    __________________________________________________ ___________
    Did have A4 Technik 170. Now got Passat B8 150 GT Indium Grey with LEDs.
    0 2 0
  2. Re: Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    And here is the result - No faults and instant on/off with the cornering function.
  3. Re: Replacement Front Fog bulbs
    Apr 2012
    Somerset
    Looks good - does it give the same power/lumens as the halogen bulb it replaced?
    Now: 2016 Passat SE Business Estate | V&C Pack | AID | DLA | TPMS
    Old: 2012 A4 Avant SE Technik | TDIe | Tech Pack High | Foldy Mirrors | TPMS | Heated Seats | Auto Hold
  4. Re: Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    So far so good. To be honest, I only wanted to get rid of the horrible yellow appearance, but they appear every bit as bright as the halogens they replaced. Took less than 10 mins to change them both.
  5. Re: Replacement Front Fog bulbs
    Aug 2007
    Hampshire
    Excellent job Technik and thanks for the images. I will change mine as soon as I can get the LEDs you recommended. The site states that the Lumens increase is from 300-400 for the standard bulb up to 750 for the LED.
  6. Re: Replacement Front Fog bulbs
    Aug 2011
    Tyne & Wear
    They're a great improvement.
  7. Re: Replacement Front Fog bulbs
    #17
    May 2016
    birmingham
    Hello mate thanks for the pictures, just ordered some led bulbs like the ones you have, but i am struggling to get the black plastic surround off. (don't want to break it) went to VW today and they said oh the clips break easily, and they take the front bumper off and wanted to charge £110 to take bumper off and fit two bulbs!!!
    Please could you tell me where to prise the bit off. Thanks for your time Ben.
  8. Re: Replacement Front Fog bulbs
    #18
    Aug 2011
    Tyne & Wear
    Wow! Can't see how removing the bumper gets access to the fog light housing - you still have to pull this cover off? My dealership told me to just pull it off. They even gave me the printed off workshop manual pages that said just pull it. When I went back and showed them the right way it was quite funny. Their manual hasn't got any reference to the screw.
    So if you look at pic 2, it is a side view of the cover taken under the silver strip that runs horizontally across the centre grill. That's where the screw hole is located. Undo that screw before you try to remove the cover.
    The hole in the front of the cover is what you use to pull the cover forwards - there's a hook tool in your toolkit, put that in and give it a pull (only after removing the screw on the side).
    As soon as it starts to come forward I'd start prising it with your fingers gently. If it breaks, the covers aren't that expensive. It would be cheaper to just break them both and order replacements than pay £110.
  9. Re: Replacement Front Fog bulbs
    #19
    Aug 2011
    Tyne & Wear
    The pics are just for the LED headlight version, but should be the same for standard. PM me if you need more help.
  10. Re: Replacement Front Fog bulbs
    #20
    Feb 2016
    Milton Keynes England
    I cannot find these bulbs online or in shops anywhere, any more suggestions where I can get any? Thanks!
  1. Question Front Fog Light Replacement
    By Dook in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-11-2013, 10:53 AM
  2. Front fog light bulbs
    By Brawn in forum Touran - Sharan - Caravelle
    Last Post: 18-12-2011, 11:42 PM
  3. change front fog lamp bulbs
    By getjasonroberts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-01-2011, 05:03 PM
  4. Replacing fog light bulbs from the front?
    By allya in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-12-2009, 09:17 PM
  5. Front fog Lamp replacement
    By sathound in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-12-2008, 11:57 AM
