Thread: Audi A3 2011 Sumphony to RNS-E Retrofit - Aux Issues
  1. Audi A3 2011 Sumphony to RNS-E Retrofit - Aux Issues
    Hi all, after a bit of advice, have searched the forum and not found a solution.
    I bought my A3 with Symphony headunit fitted, and decided to upgrade to the RNS-E (used unit bought on Ebay).
    On the Symphony unit the standard AUX input under the armrest works fine, however, I cannot get any sound from the Aux input when using the RNS-E unit.
    The Aux option on the RNS selects fine, I just cant get any sound out of it.
    I suspect that it may need to be coded with VCDS or something similar, but I am not 100% sure that an adjustment to the wiring may be needed.
    Any info would be greatly appreciated! Many thanks in advance.
  2. Re: Audi A3 2011 Sumphony to RNS-E Retrofit - Aux Issues
    May 2014
    Darlington
    78 Post(s)
    Wiring is different on the RNS-E, on the back of the RNS-E you will see an unused connector the pins go into there. Search AUX retrofit on the RNS-E there have been plenty of write-ups on how to do this.
  1. Please Help Rns-e Aux in Help
    By Drewspeed150 in forum In Car Entertainment
    Last Post: 15-05-2014, 12:13 PM
  2. RNS-E Aux in retrofit, done!
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-10-2013, 12:19 PM
  3. Audi rns-e retrofit
    By Ukdanny666 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-09-2013, 07:25 AM
  4. Replies: 0
    Last Post: 12-05-2013, 10:17 PM
