Thread: Strange rattle and 'whoosh' noise during acceleration after manifold & actuator change
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Strange rattle and 'whoosh' noise during acceleration after manifold & actuator change
    Pembrokeshire
    22 Post(s)
    either a boost pipe is loose as crasher says, or something on the exhaust side is loose, maybe the egr or the exhaust manifold gasket has broken on a port, or is loose and leaking.
  2. Re: Strange rattle and 'whoosh' noise during acceleration after manifold & actuator change
    Mar 2010
    Galway, Ireland
    Just a quick update on this issue... The rattling noise transpired to be a loose bolt on the dual mass flywheel which had been fitted Nov '14. Had to change the drive plate and some new bolts,,, the fly wheel was OK as the bolt had loosened over a period of time and then started to rub off the dust plate cover. Simple enough fix in the end but boy did it cause a lot of confusion on what the problem was!
    Thanks to all those that tried to help me out on this!
    '09 A4 SE 143hp Multitronic - Quartz Grey
  3. Re: Strange rattle and 'whoosh' noise during acceleration after manifold & actuator change
    Oct 2015
    GB
    Phew, Lucky u caught it in time then
    Sent from my SM-A300FU using Tapatalk
  4. Re: Strange rattle and 'whoosh' noise during acceleration after manifold & actuator change
    Dec 2007
    8 Post(s)
    Is the whoosh also gone?.
  5. Re: Strange rattle and 'whoosh' noise during acceleration after manifold & actuator change
    Mar 2010
    Galway, Ireland
    Yes... the 'whoosh' noise was the bolt head spinning on the dust plate cover.
  6. Re: Strange rattle and 'whoosh' noise during acceleration after manifold & actuator change
    1840 Post(s)
    We did the first cam belt change on a Superb 2L CR TDI 8v last week and the idler roller nut was loose, only held in place by the plastic cover...
    0 2 0
  1. A6 2.0 Tdi Inlet manifold actuator
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-01-2013, 04:10 AM
  2. Whistle, whoosh noise
    By duncmill in forum 1.9TDi - Engine
    Last Post: 20-03-2011, 12:37 PM
  3. Strange Air Suction Noise on acceleration
    By AJC2008 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-07-2010, 04:01 PM
  4. Strange noise on acceleration
    By leeoz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-05-2010, 10:42 PM
  5. Strange engine noise during acceleration 1.9tdi
    By TDIQuattro1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-09-2009, 03:55 AM
