Thread: Flat Battery - Blackpool illuminations
Results 1 to 10 of 20
  1. Flat Battery - Blackpool illuminations
    Apr 2009
    Largs, North Ayrshire
    Good evening all. Finally back to the forum after a long time away, glad to be back.
    Went out to the car Monday morning and my battery was flat. Finally after a jump start I got a load of dash board lights and warning pings etc. They included, steering, ABS, Parking sensors, Airbag etc. They have all seemed to have cleared apart from the Parking Sensors error. Just get a long audible warning and the button next to the gear stick flashes and no sensors. I have done an auto scan which has found some errors.
    I was wondering if anyone with more of a knowledge of VAGCOM could have a look at the log below and possibly a solution to get these rectified. Any input is much appreciated.
    Code:
    Wednesday,25,November,2015,19:56:04:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    VIN: WVWZZZ3CZ9P062245   License Plate:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 72
    01-Engine -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 QF    HW: 03L 907 309
       Component: R4 2,0L EDC G000SG  6211
       Revision: 13H01---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 83968 299 740166
       VCID: 79F90B6F302C89D6D3D-802C
    1 Fault Found:
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 000 - Supply Voltage - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 114918 km
                        Time Indication: 0
                        Date: 2007.14.06
                        Time: 09:05:52
                 Freeze Frame:
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Voltage: 6.38 V
                        Load: 100.0 %
                        Load: 100.0 %
                        Mass Air / Rev.: 985.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
       Component: J104    C4 440 V2   0013
       Revision: --025---    Serial number: 00000786511683
       Coding: 0001322
       Shop #: WSC 00028 028 00001
       VCID: 2F6DF537BEE897663D9-807A
    No fault code found.
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No SW: 1K0 820 047 JE    HW: 1K0 820 047 JE
       Component: Climatic PQ35   143 1313
       Revision: 00143033    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 70EF364B6356C89E643-8025
    1 Fault Found:
    00532 - Supply Voltage B+
                002 - Lower Limit Exceeded - Intermittent
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
       Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
       Component: Bordnetz-SG     H54 2602
       Revision: 00H54000    Serial number: 00000006054876
       Coding: 00808F0700041A00470A00000F000000000859435C000120000000000000
       VCID: 326BFC43ADDABA8E527-8067
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 201108 022  0601
       Coding: 00046997
       Shop #: WSC 00028
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 3C8 919 475     HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0007
       Revision: --------    Serial number: 97540834413727
       Coding: 100002
       VCID: F1E9B34F285C4196EBD-80A4
    2 Faults Found:
    00446 - Function Limitation due to Under-Voltage
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 40
                        Mileage: 114918 km
                        Time Indication: 0
                        Date: 2007.14.06
                        Time: 08:34:02
                 Freeze Frame:
                        Temperature: 6.0°C
    16347 - Control Module - EEPROM Error
                014 - Defective
                 Freeze Frame:
                        Fault Status: 01101110
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 0
                        Time Indication: 15
                 Freeze Frame:
                        Temperature: 0.0°C
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__00Q VW10 HI   1815
       Revision: 19013000    Serial number: 0039DPR6Y9UR
       Coding: 0012369
       VCID: 3B75D1677A907BC6811-806E
       Subsystem 1 - Serial number: 6333FTS657133408
       Subsystem 2 - Serial number: 6343FTS631883398
       Subsystem 3 - Serial number: 6353ETS6DTPOU5KR
       Subsystem 4 - Serial number: 6363ETS6VHDPU5KJ
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 172
                        Mileage: 114918 km
                        Time Indication: 0
                        Date: 2007.14.06
                        Time: 08:34:07
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AK    HW: 3C0 953 549 AK
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CP
       Coding: 0000111
       VCID: 75E1075F1C34EDB6B75-8020
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           002 0030
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3C0 920 971 R    HW: 3C0 920 971 R
       Component: KOMBI         H04 0107
       Coding: 460F00
       Shop #: WSC 00028 028 00020
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
       ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
       VCID: 3467FA5B9FCEB4BE40B-8061
    Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P08C08001B
       Coding: F9A07F06000202001003
       VCID: 2A5BE423850AF24EEA7-807F
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
       Component:    IMMO         043 0383
       Revision: 00043000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 7AFB1463352A82CEDA7-802F
       Subsystem 1 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 4
                        Fault Frequency: 3
                        Reset counter: 172
                        Mileage: 0 km
                        Time Indication: 0
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
       Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
       Component: J386  TUER-SG FT    1518
       Revision: 72009005    Serial number: 00000819089119
       Coding: 0000693
       VCID: 6FED35377E68D7667D9-803A
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 196    2501
       Revision: 00H15000
       VCID: 2C57E23B8FFEEC7E18B-8079
    1 Fault Found:
    00750 - Warning Lamp
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 191
                        Mileage: 114918 km
                        Time Indication: 0
                 Freeze Frame:
                        Voltage: 10.25 V
                            PD
                        Temperature: 6.0°C
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Speed: 0.0 km/h
                        Count: 0
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ46 ELV 043 0612
       Coding: 01910A0001860E763004941570085FCE107C01
       Subsystem 1 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HORN H08 9001
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
       Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
       Component: J387  TUER-SG BT    1518
       Revision: 72009005    Serial number: 00000764389112
       Coding: 0000692
    Address 53: Parking Brake        Labels: 5N0-907-801.clb
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000219007
       Coding: 0000057
       VCID: 285F1E2B9B06C05EFC3-807D
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  012 0029
       Revision: 00000000    Serial number: VWZ1Z2H5888913
       Coding: 0500040004
       VCID: 65C1571F6C941D36075-8030
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 4
                        Reset counter: 172
                        Mileage: 114918 km
                        Time Indication: 0
                        Date: 2007.14.06
                        Time: 08:34:03
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 172
                        Mileage: 114918 km
                        Time Indication: 0
                        Date: 2007.14.06
                        Time: 09:06:41
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0308
       Revision: 41004101    Serial number: 00000000756142
       Coding: 0000144
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0308
       Revision: 41004101    Serial number: 00000000760590
       Coding: 0000144
       VCID: 71E9334F685CC1966BD-8024
    End   ---------------------------------------------------------------------
    cheers
  2. Re: Flat Battery - Blackpool illuminations
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    See if you can clear them all by going into the Fault Codes area of each controller. Some are 2007 so will probably be no longer valid. Then take the car out for a 30 minute run and rescan when you get back. Post the new scan if there are still fault codes.
    Mad Mitch
  3. Re: Flat Battery - Blackpool illuminations
    Apr 2009
    Hi Mitch, many thanks for your reply. I will clear them before I leave work and post the re scan later. It's strange that they are from 2007 as I have a 59 plate.
  4. Re: Flat Battery - Blackpool illuminations
    Apr 2009
    Hi Mitch, faults cleared and re-scanned. Results below
    Code:
    Thursday,26,November,2015,18:06:06:62939VCDS -- Windows Based VAG/VAS Emulator
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
       Coding: 0000072
    Cannot be reached
       Coding: 00046997
       Shop #: WSC 00028
       Coding: 100002
    1 Fault Found:
                014 - Defective
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 0
                        Time Indication: 15
                 Freeze Frame:
                        Temperature: 0.0°C
       Coding: 0012369
       Coding: 0000111
       Coding: 460F00
       Coding: 0000693
       Revision: 00H15000
       Coding: 0000692
       Coding: 0000057
       Coding: 0500040004
    1 Fault Found:
    03138 - Input AUX IN
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 142
                        Mileage: 115283 km
                        Time Indication: 0
                        Date: 2007.14.09
                        Time: 17:11:24
       Coding: 0000144
       Coding: 0000144
  5. Re: Flat Battery - Blackpool illuminations
    Norfolk
    Disconnect battery, touch + and - leads together. reconnect battery. Clear all fault codes , test drive and scan for new codes.
  6. Re: Flat Battery - Blackpool illuminations
    Sep 2008
    SE London
    Have you changed your battery now?
  7. Re: Flat Battery - Blackpool illuminations
    Apr 2009
    Changed the battery, touched the + - together, driven round, cleared faults, done another scan and still got the Park Assist Error. This error only became apparent after my flat battery, has this done something to the unit? Log below:
    Code:
    Sunday,29,November,2015,16:02:22:62939VCDS -- Windows Based VAG/VAS Emulator
    56-Radio -- Status: OK 0000
       Coding: 0000072
       Coding: 0001322
       Coding: 00046997
       Shop #: WSC 00028
       Coding: 100002
    1 Fault Found:
                014 - Defective
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 0
                        Time Indication: 15
                 Freeze Frame:
                        Temperature: 0.0°C
       Coding: 0012369
       Coding: 0000111
       Coding: 460F00
       Coding: 0000693
       Revision: 00H15000
       Coding: 0000692
       Coding: 0000057
       Coding: 0500040004
       Coding: 0000144
       Coding: 0000144
  8. Re: Flat Battery - Blackpool illuminations
    Sep 2008
    SE London
    Most of your codings have been done with a WSC of
    What's the coding history of this car?
    You might want to try removing the coding (all zeroes) using a WSC of WSC 12345 123 12345
    Some modules are pickey as to what WSC code is used for them.
    And then re-enter your previous coding using the same WSC
    This is just a guess, something I'd try were I there. If you still get EEPROM error, like your previous scan, then can you tell when you didn't have this fault from your previously saved scans?
    Be prepared for having to replace your Parking Distance Control module though. Usually EEPROMs can only be re-flashed by dealer
  9. Re: Flat Battery - Blackpool illuminations
    Apr 2009
    Hi Richard.
    I only got the car in September this year. I have been running an auto scan on my laptop. I don't know what has been done on the car previously. The car had few problems that at Arnold Clark sorted in September
  10. Re: Flat Battery - Blackpool illuminations
    Sep 2008
    SE London
    Quote Originally Posted by billythetidd View Post
    Hi Richard. I only got the car in September this year. I have been running an auto scan on my laptop. I don't know what has been done on the car previously. The car had few problems that at all Clark sorted in September
    Seems like someone's been at it with VCDS before you then.
    I've got a bad habit of adding stuff to an existing post. Which I did after your reply's time stamp. See whether the re-code works?
  1. Battery going flat
    By 20vtiny in forum Golf MK5 - 2004 - 2009
    Last Post: 02-09-2016, 07:21 PM
  2. Blackpool illuminations
    By wacko in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-09-2015, 11:00 PM
  3. Flat Battery.
    By alang498 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-04-2015, 10:31 PM
  4. More lights than Blackpool Illuminations!
    By JohnHuson in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-03-2013, 08:17 PM
  5. flat battery
    By northernangel in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-06-2011, 08:34 AM
