Thread: Dpf :(
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Dpf :(
    Nov 2013
    mandfield woodhouse
    Hi guys tricky one here
    Car is a 2.0 tdi CAGA engine manual 6 speed jws gearbox.
    last month had a problem where revs would rise to 1k and sit there so I thought great dpf is regenerating so I waited 30-40 mins nothing was "stuck" in regen? When i revved the car slightly sounded strange like a snorkle/gasy sound, left it running then coolant temp light came on so switched the car straight off... turned it back on eventually when cooled down did appear again, so took it to garage scanned it nothing so he changed dpf sensor and put some forte dpf cleaner in.... and did something to the sensor on the coolant tank as he said it wasn't reading correctly or something?
    Since having the car back only put say 30 quid worth of diesel in so wasn't over half a tank, all was well.
    Saturday morning before work I rimmed the car was full got to work no worries but on the way back from work pulled up and it was doing the same thing again grrrr and the snorkel noise that was there while trying to regenerate is there while not regenerating this might of been there all the time and never notice it, but when you say in 1st waiting to go into 2nd must be when revs drop on change the snorkel, gas noise is there.....
    So since Saturday it hasn't happened but this noise is still there
    Sorry for the LONG post but has ANYONE had similar issues?
    Worth noting as well I only run on shell v power diesel had the car when it was on 82k now on 86k.
  2. Re: Dpf :(
    Nov 2013
    mandfield woodhouse
    Just like to add never has there been any lights on dashboard no dpf light no engine management like either
  3. Re: Dpf :(
    1840 Post(s)
    Odd to say the least, it would be interesting to have the DPF Ash Mass and soot loading blocks looked at to see what they are. What year is the car and can you see the part number of the DPF sensor? You may need a mirror. Do you know if he calibrated the new DPF pressure sensor.
  4. Re: Dpf :(
    Nov 2013
    mandfield woodhouse
    Thanks for the reply, I know it's a bosch one that's all I know, I'm not sure if he re calibrated it to be honest he's a vw audi specialist in mansfield do deal with him through work so I know he knows his stuff.
    I've spoken to a mate of mine going to try and force regen on Saturday see if that sorts it
  5. Re: Dpf :(
    1840 Post(s)
    It depends on what the loading values are, if they are too high it will not let it happen BUT there would be warning lights and codes to back this up.
  6. Re: Dpf :(
    Nov 2013
    mandfield woodhouse
    No warning lights as of yet, and his program it just says about regeneration but doesn't give the load totals like it does on other vehicles he does it with. Strange
  7. Re: Dpf :(
    Nov 2013
    mandfield woodhouse
    Got the car forced regenerated, within 3/4 weeks its back again same problem ... maybe its because I put some cleaner through the system the other day im confused to be honest now
  8. Re: Dpf :(
    1840 Post(s)
    You need to know the ash mass and soot loading values. I would be recommending the dpf be taken off and cleaned and when it goes back on, a new pressure sensor fitted and calibrated with the ash mass altered to 25% of the maximum value, then see if a regen is required.
  9. Re: Dpf :(
    Nov 2013
    mandfield woodhouse
    Thanks, ill look into this its had a new pressure sensor fitted although im not sure if he calibrated it, id of thought he would of done he knows his stuff. Any idea how much that would cost Crasher as im sure from what ive been told its not that easy getting at these DPF's on a CAGA engine.
  10. Re: Dpf :(
    1840 Post(s)
    Yes they are an **** to remove and refit, it takes one of my chaps about six hours in total so 6x £per hour and £250 for the DPF clean plus £50 ish for odds and sos such as bolts, gaskets etc.
  1. DPF pressure sensor or just a blocked DPF
    By dan2485 in forum VCDS - General Questions
    Last Post: 30-04-2018, 09:24 AM
  2. Replies: 4
    Last Post: 04-09-2016, 11:26 PM
  3. Dpf
    By stucbr1100 in forum Chat - Anything with wheels
    Last Post: 18-09-2014, 02:23 PM
  4. Dpf
    By Luke3120 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-04-2013, 01:55 PM
  5. Dpf
    By roadiescot in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-02-2011, 02:03 PM
