Thread: Cam sensor issues 1.4 ecomotive ibiza
  1. Cam sensor issues 1.4 ecomotive ibiza
    Gwent
    I just. Had a timing belt kit fitted, the car came back, was difficult to start when warm, impossible to start cold the following day. It would fire as normal, but cut out after 2-3 seconds. Fault code was 012296 cam pos sensor signal out of range.
    I managed to get the car running by unplugging the cam sensor. I replaced the cam sensor with a beru item from ecp. Car now starts but has long cranking time and not a very clear fire up when warm
    Fault code now is 000833 cam position sensor implausible signal
    Any suggestions welcome please
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  2. Re: Cam sensor issues 1.4 ecomotive ibiza
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    re-check the pulley / crank positions, sounds like a tooth out
  3. Re: Cam sensor issues 1.4 ecomotive ibiza
    1840 Post(s)
    Yes, it is pretty much a certainty that they have set the the cam timing incorrectly, they probably did not use the correct locking pins and this can allow the exhaust cam to move.
    1 1 0
  4. Re: Cam sensor issues 1.4 ecomotive ibiza
    Nov 2010
    104 Post(s)
    look for tell tale tippex marks if you pop off the top cover, bit of a giveaway that they didn't use the pins ! crank may have been off as well when they fitted the belt.
  5. Re: Cam sensor issues 1.4 ecomotive ibiza
    Gwent
    Sorry I should have mentioned, it is a 2009 6L tdi with I think a bms Engine. With the cam pulley pinned, the notch on the harmonic damper lines up with the pointer on the lower timing cover, to me it appears to be right. IF i need to reset the timing from scratch how would I go about this, or is there a torsion value I could check?
    I Appreciate your answers cheers
  6. Re: Cam sensor issues 1.4 ecomotive ibiza
    1840 Post(s)
    You MUST set these with a crank locking plate and a cam locking pin, the adjustment is very fine.
  7. Re: Cam sensor issues 1.4 ecomotive ibiza
    Gwent
    Finally put this one to bed, used the locking tools, it was about 1/2 of a tooth out at the crank. Initially, still had poor starting and was still throwing up the implausible signal fault code. I decided to refit the original Abe cam pos sensor, which thankfully did the trick.
  1. Ultra-frugal seat ibiza ecomotive sets new economy record
    Last Post: 10-05-2009, 03:48 PM
  2. Ultra-frugal seat ibiza ecomotive sets new economy record
    Last Post: 09-05-2009, 09:45 AM
  3. cam belt chain tensioner on seat ibiza
    By Dave Ridley in forum Ibiza - Cordoba
    Last Post: 28-05-2008, 05:41 AM
  4. Replies: 0
    Last Post: 24-12-2007, 07:16 PM
  5. Replies: 0
    Last Post: 12-09-2007, 08:57 PM
