Thread: Confused about which engine oil to use to top up - please help..
Results 1 to 9 of 9
  1. Confused about which engine oil to use to top up - please help..
    Dec 2011
    leeds
    Hi All
    I am somewhat confused with all the numbers and specifications. When I called Audi they recommended Shell 0w-30 as this work for the regular service and the longlife service and meets 504.00/507.00 (507.00 I believe is for the DPF which I do not have).
    So I picked up some Castrol Edge Titanium FST 0w-30 thinking this will do the same job. When I looked on the specs it said 502.00/505.00.
    To confuse things even more the Castrol Edge Titanium FST 5w-30 meets 504.00/507.00.
    So which oil do I use? Audi told me they have moved from 5w-30 to 0w-30.
    Will the Castrol Edge 0w-30 do the job? If I have 5w-30 currently and top up with 0w-30 will it cause an issue?
    Thanks All.
    Chatty
  2. Re: Confused about which engine oil to use to top up - please help..
    46 Post(s)
    Which engine is it?
  3. Re: Confused about which engine oil to use to top up - please help..
    Dec 2011
    leeds
    Sorry missed this out BRE engine A4 2.0 TDI Sline.
    Chatty
  4. Re: Confused about which engine oil to use to top up - please help..
    46 Post(s)
    It's definitely 5W30, either Castrol Edge or Quantum LL3.
  5. Re: Confused about which engine oil to use to top up - please help..
    Dec 2011
    leeds
    Thanks Chris
    I'll change the oil I bought and use 5w30.
    cheers
  6. Re: Confused about which engine oil to use to top up - please help..
    Dec 2009
    southampton uk
    If you don't know whats in there already I would do an oil change not a top up .I prefer Quantum f/s 5/40 and our local TPS often do deals for quantity
  7. Re: Confused about which engine oil to use to top up - please help..
    Nov 2010
    Bracknell, UK
    Quote Originally Posted by chatty123 View Post
    I have a similar engine in mine, been using Shell Helix Ultra AVL 5W-30 for the past four years. Audi UK website says preferred oil is Castrol EDGE Professional 5W-30 Audi oil < Servicing and MOT < Owners Area < Audi < Audi UK so you'd be okay with that, or any of the alt brands mentioned in this thread that are 5W-30 and meet 504.00/507.00.
    > Current: B9 2016 Audi A4 2.0 S-Line TFSI S Tronic. Mythos Black. A connected computer on wheels
    > Previous: B7 2006 Audi A4 2.0 S-Line TDI Multitronic. Pearlescent Black. High low-tech
  8. Re: Confused about which engine oil to use to top up - please help..
    May 2012
    Everywhere
    308 Post(s)
    Quote Originally Posted by mikeybutch View Post
    Why do you prefer it ??
  9. Re: Confused about which engine oil to use to top up - please help..
    Dec 2011
    leeds
    Hi All
    Mikeybutch - Oil change was done under a service by Audi in August. I was enquiring in case the level had dropped which it hasn't yet, always best to have some oil handy. Audi advised it was 0w-30 hence the question although I have always had a top up of 5w-30 from Audi from past services. 504.00/507.00.
    Jangles - thanks this is what I will pick up after exchange the current oil I have.
    Thanks All
    Chatty
  1. 1.9tdi which engine oil to use - confused
    By johnmccracken in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2014, 02:16 PM
  2. Wanted Avant 1.8T sport AVJ engine lost oil pressure needed top end or full engine
    By Graham92 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-04-2013, 11:58 AM
  3. Please Help Oil all over the engine top to bottom!
    By TheBlueVoice in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-09-2011, 10:32 AM
  4. Question Brake fluid top up - im confused
    By bambamjj in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-01-2011, 10:35 PM
  5. Correct top-up engine oil?
    By Vib_analyst in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-02-2010, 10:12 AM
