Thread: Non starter. Air in fuel lines?
  1. Non starter. Air in fuel lines?
    Sep 2015
    United Kingdom
    *was*on here not so*long ago with a possible failed fuel pump. It was the module that had gone so i have now had that repaired and refitted it the codes the ecu was throwing have now gone.
    When fault finding before being sure it was the edc at fault i undone the fuel lines to the injectors,Even took the rocker cover off (as i had a needle lift sensor) meaning i took the return/overflow lines off too.
    Even now the fuel still gets to the injectors, ive topped the filter up, leaving the bleed nipple open. I have even tried cracking the injectors one at a time to let the air out whilst turning the engine over and still no luck. Its an auto so i can't bump start. My next step is going to be repeat*the process + some easy start.
    When i loosen the the injectors should i be doing them one at a time. Or just crack them half/all off a turn or so (not tried that yet)
    Or if there are any other tips*you guys know then please let me know
    Sent from my SM-G900F using Tapatalk
  2. Re: Non starter. Air in fuel lines?
    Dec 2007
    8 Post(s)
    What engine?
    You probably need to have the filter bleed screw closed when cranking.
    May help to suck the fuel up to the filter with a vacuum to assist initial starting
  3. Re: Non starter. Air in fuel lines?
    Sep 2015
    United Kingdom
    Well i tried it both ways anyway.
    Its a 2.5 tdi v6 ake
    I have seen like a syringe style thing to help get the air out. Unsure as to where i would use it on my fuel system. Only place i can see is the bleed nipple on the filter
  1. air in fuel lines?
    By toptek in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-08-2011, 07:06 AM
  2. Question how do I find the position of fuel lines on fuel distributor?
    By 86Audi400s1.8 in forum Chat - Completely Off Topic
    Last Post: 07-09-2009, 11:24 PM
  3. Fuel Lines
    By comedystu in forum Chat - Anything with wheels
    Last Post: 22-02-2009, 01:09 PM
  4. MK4 Golf TDI cold start problems: how do I remove air from fuel lines
    By peteheat in forum Golf MK4 - 1999 - 2004
    Last Post: 28-09-2007, 01:37 PM
  5. Air in fuel lines 2.5 TDi
    By brickit in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-08-2007, 09:23 PM
