Thread: Headlight switch question
  1. Headlight switch question
    Dec 2009
    Amesbury, Wiltshire
    18 Post(s)
    I have a 2014 Ultra with auto lights. The dipped beam lamp does not illuminate when dipped beam lights are on (even when manually selected dipped beam) - should it? It does glow orange like the other position symbols when lights are off. The sidelights lamp illuminates green when they are on, and I would expect the dipped beam also to illuminate (as they do in our TT with auto lights). The car warranty is about to expire so I wonder whether it is a fault or if it's normal - although hardly a significant issue!
    Many thanks,
    Rob
  2. Re: Headlight switch question
    Apr 2009
    Surrey
    174 Post(s)
    Pretty sure it is normal. Only the sidelights part goes green when they or the headlights are on. When set to Auto of course there is no concept of sidelights being on on their own as Auto always switches the headlights on
  3. Re: Headlight switch question
    Dec 2009
    Amesbury, Wiltshire
    18 Post(s)
    Quote Originally Posted by johnsimcox View Post
    Thank you - I had always assumed it was normal until we got the TT and the headlight lamp illuminates when on! So thought I'd check...
  4. Re: Headlight switch question
    Jun 2015
    Ireland
    69 Post(s)
    Quote Originally Posted by robes401 View Post
    Many thanks,
    Rob
    I noticed the same. Your post made me to go outside and double check it. It is normal, dipped beam does not illuminate green.
  1. A6 headlight switch LHD same as RHD ?????????
    By ianb4310 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-06-2017, 07:39 PM
  2. Headlight Switch
    By dan.taylor.1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2013, 08:31 PM
  3. Question B6 headlight switch
    By domo73@tiscali. in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-12-2011, 07:20 PM
  4. headlight switch.
    By ckrisrok in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2010, 07:53 PM
  5. a4 headlight switch
    By bez101 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2009, 09:15 PM
