Thread: whistling noise
  1. whistling noise
    Aug 2006
    Hi all
    Model ..passat 1.8 s
    year... W 2000
    I have a strange whistling noise coming from the what seems to be the front end of the car ( engine compartment) when I depress the accelerator lasting for a bout a second in each gear but does not happen when the vehicle is in neutral or the clutch depressed. also does not happen until the engine is warm. Recently had a new cat fitted.
    Jul 2007
    hi Ihave the same problem on my 115 pd passat but don't know what the problem is
  3. Re: whistling noise
    likewise, i have this problem on my 2000 passat, i wish someone will come out. How did you solve it?
  4. Re: whistling noise
    Mar 2007
    Belt tensioners could be the problem or EGR valve blocking up with carbon also can cause a whistling noise. Could also be the vacuum attached to that unit failing.
  1. What's the noise?
    By Benners in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2007, 10:24 PM
  2. got a noise
    By new to vw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 05:02 PM
  3. Noise!!
    By Dips in forum Audi A3 - Archive Topics
    Last Post: 29-04-2007, 02:34 PM
  4. Whistling Turbo
    By alecmac in forum Vento - 1994 - 1998
    Last Post: 15-03-2007, 12:31 AM
  5. Brakes making whistling noise
    By thecoolalhambra in forum Passat - Archive Topics
    Last Post: 18-09-2006, 03:11 PM
