Thread: 1.6 AZD intake air preheating thermostat - available separately?
Results 1 to 10 of 12
  1. 1.6 AZD intake air preheating thermostat - available separately?
    Mar 2013
    As mentioned here I found my 1.6 (AZD engine)'s intake air preheating thermostat was stuck on 100% hot air. As a temporary fix I've wedged it to be 100% ambient air, but I'd like to replace the thermostat.
    On my car the thermostat is in the engine cover/air intake assembly which is part number 036129607BE. The diagram/parts catalogue I'm looking doesn't mention the thermostat. Anyone know if it's available by itself (from VW or anywhere else)? It seems a bit of a waste to have to buy the whole assembly, which is probably pretty expensive, for the sake of a thermostat. Anyone know how much the whole assembly is from VW?
    The thermostat is marked #2 in the bottom picture of this page.
    Many thanks.
  2. Re: 1.6 AZD intake air preheating thermostat - available separately?
    1840 Post(s)
    You can't buy any internal parts for that filter unit, it is £164.24 retail inc. VAT from VW dealers. It is only used on the AZD engine in the Golf 4/Bora.
  3. Re: 1.6 AZD intake air preheating thermostat - available separately?
    Mar 2013
    Ouch, ok thanks very much for the info! Perhaps I should just leave it wedged on 100% ambient air...
  4. Re: 1.6 AZD intake air preheating thermostat - available separately?
    1840 Post(s)
    There is a significant risk of the throttle body butterfly freezing up with ice during cold wet weather and this can lead to hard to trace (because it melts in seconds) cold weather running issues with the EPC light coming on and sowing the throttle body to be faulty when it isn't.
    1 1 0
  5. Re: 1.6 AZD intake air preheating thermostat - available separately?
    Pembrokeshire
    22 Post(s)
    just like mk2 golfs with the pierburg carby. if only the intenet was about back then, would have been a lot easier to solve.
  6. Re: 1.6 AZD intake air preheating thermostat - available separately?
    1840 Post(s)
    Similar but on a carb it actually freezes the fuel. Anyway, I didn't need any tinterweb to help me....
    1 1 0
  7. Re: 1.6 AZD intake air preheating thermostat - available separately?
    Pembrokeshire
    22 Post(s)
  8. Re: 1.6 AZD intake air preheating thermostat - available separately?
    1840 Post(s)
  9. Re: 1.6 AZD intake air preheating thermostat - available separately?
    Pembrokeshire
    22 Post(s)
    i finally found the problem by running it until it stopped, then very quickly pulled the air cleaner off, to find a lot of ice down the carb, yet it wasn't even cold outside. physics is amazing..
  10. Re: 1.6 AZD intake air preheating thermostat - available separately?
    Mar 2013
    Aha, that doesn't sound like much fun. I'll get it changed then.
    I also noticed that my cylinder #3 coil pack is taller than the rest, and was rubbing on the intake directly under the thermostat. Presumably transmitting vibration into it. Not sure if that'd contribute to the thermostat's demise. I've got a spare coil pack in the boot so I'll swap them before replacing the intake.
    Cheers.
  1. Air intake
    By Cooke85 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-04-2014, 08:32 PM
  2. air intake
    By edgr951 in forum Golf MK3 - 1993 - 1999
    Last Post: 21-11-2008, 05:34 PM
  3. Replies: 0
    Last Post: 26-07-2008, 02:58 PM
  4. Recommend an cold-air intake / air-filter?
    By RobBentley in forum Bora - 1998 - 2005
    Last Post: 20-07-2008, 12:45 PM
  5. Air filters, Air flow And MAF. what could cause air intake issues?
    By Ben in forum Chat - Anything with wheels
    Last Post: 09-01-2008, 12:02 AM
