Thread: MK5 TDI injector/ECU issue? please help
  1. MK5 TDI injector/ECU issue? please help
    Oct 2015
    London
    Hi, 1st post (anywhere!) so please excuse if I muck this right up!
    OK; I have a 2004 MK5 1.9TDI Golf (BKC engine code and the 105ps version). Manual 5 speed. it has high mileage @ 184k, but was running sweet as anything! However over the last few weeks it has developed a nasty problem. A bit lumpy on idle (I have already replaced the MAF!) and then once 'opened up' a little at around 3000rpm seems to cut out a cylinder, the car runs VERY jittery! then if I pull over switch off, on again it runs fine for a mile or two - or more at times! no engine lights come on or anything like that........... I've had it diagnosed and 'Electrical issue to injector 1' was the result on the 1 occasion it did flash a dash light. Anyone any idea what could be causing this??? ECU? Injector issue???? Please please help....... thanks
  2. Re: MK5 TDI injector/ECU issue??... please help :o(
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Hi rik, welcome to forum. Symptoms sound like injector wiring loom needs replacing.
    2 2 0
  3. Re: MK5 TDI injector/ECU issue??... please help :o(
    Pembrokeshire
    22 Post(s)
    ^^^^^ seconded ^^^^^^^
    2 1 0
  4. Re: MK5 TDI injector/ECU issue??... please help :o(
    Oct 2015
    London
    Hi, thanks for quick response, looked on one of the 'manual' sites and I need to get hold of 2x specialist tools (the job seems fairly straight forward to do!).... any idea where I can get hold of the 'T10310 & T10312???
    I've linked to the page below........ Had a quick look and doesn't seem too common????
    Removing and installing pre-wired wiring harness for unit injectors and glow plugs
  5. Re: MK5 TDI injector/ECU issue??... please help :o(
    Nov 2010
    104 Post(s)
    Don't think you'll need the tools, search for you tube vids. Shouldn't take a garage long to do if you're in doubt.
  6. Re: MK5 TDI injector/ECU issue??... please help :o(
    Oct 2015
    London
    Hi Guys,
    Just a quick response to thank you. Bought the wiring loom, £80 (Genuine part), 2.5hrs later I had it changed over - harder part is removing the rocker cover rather than the install itself! but needless to say it sorted the problem..... so many thanks for diagnosing it! appreciated.........
    Rich
    0 2 0
  7. Re: MK5 TDI injector/ECU issue??... please help :o(
    Nov 2010
    104 Post(s)
    Nice one Rich, glad it sorted it out.
  1. 2.5 tdi 2005 a4 injector pump issue?
    By tregz544 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2015, 07:21 PM
  2. Misfire / injector issue in 2.0 tdi
    By CountryAlfa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-04-2015, 07:32 PM
  3. Question A8 tdi injector issue
    By a8tdi in forum A8 - S8 - V8
    Last Post: 05-01-2013, 05:35 PM
  4. Please Help 02 GT TDI 150pd injector issue????
    By ch4chi in forum Golf MK4 - 1999 - 2004
    Last Post: 15-02-2010, 11:21 AM
