Thread: Passat b6 saloon dedicated Electrics routing
Results 1 to 8 of 8
  1. Passat b6 saloon dedicated Electrics routing
    Sep 2015
    Lincoln
    Hello
    Does anyone know the routing for the dedicated towbar Electrics on a passat b6. The instructions are confusing.
    I have read all the Electrics go to the drivers side but the pictures also show passenger side! Also do the wires run under the rear seats or only around the perimeter of the inside trim?
    Dave
  2. Re: Passat b6 saloon dedicated Electrics routing
    Mar 2009
    Manchester, England
    Hi Dave, what year is the car and what make is the wiring kit you have?
    PF Jones Towbars | National Mobile Towbar Fitting | Audi Towbars
    We will beat any like for like price on all Witter and Westfalia Towbars 0161 872 4755
  3. Re: Passat b6 saloon dedicated Electrics routing
    Sep 2015
    Lincoln
    Hi, it's a 2008. I got the towbar from you. The electrics are genuine vw. Thanks.
    Sent from my LG-D855 using Tapatalk
  4. Re: Passat b6 saloon dedicated Electrics routing
    Mar 2009
    Manchester, England
    Hi Dave, I know the instructions are crap, you run it all down the drivers side, it should all become clear when you are doing the job with it all in front of you.
    If you get stuck, give us a call with your invoice and our tech guy will speak to you.
    Thanks.
  5. Re: Passat b6 saloon dedicated Electrics routing
    Sep 2015
    Lincoln
    Thanks for your help. Does the module still go on the drivers side as this has a fixing point plus an earth on the passenger side rear arch that I assume is a dedicated spot that already has the fixing points and earth point? Thanks
  6. Re: Passat b6 saloon dedicated Electrics routing
    Mar 2009
    Manchester, England
    Hi Dave, the module needs mounting on the left side with the plugs facing downwards, the earth point is in the same area. As below
  7. Re: Passat b6 saloon dedicated Electrics routing
    Sep 2015
    Lincoln
    Just got around to this! My loom splits in two at the rear seats once all the rear module and cable is connected. One length of the cable fits perfect length wise to the drivers side fuse area. The other section is far too short to reach but is the perfect length to go to the passenger side fuse box! Left quite confused now!
  8. Re: Passat b6 saloon dedicated Electrics routing
    Jul 2016
    Launceston Cornwall
    this has helped me with my passata lot.
  1. Does my '08 Jetta have a towbar electrics socket for dedicated electrics?
    By EdF in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 21-10-2013, 01:23 PM
  2. Dedicated electrics
    By Gringo Starr in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 14-10-2013, 10:39 AM
  3. A4 B8 Westfalia Towbar and Dedicated Electrics
    By madsplasher in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 25-07-2013, 11:43 PM
  4. Golf Mk6 GTI - Tow Bar & Electrics. Bypass Relay or Dedicated???
    By nc35 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 11-07-2011, 04:55 PM
  5. Replies: 0
    Last Post: 30-08-2010, 08:05 PM
