Thread: Lights will not turn off
  1. Lights will not turn off
    Apr 2013
    gosport uk
    2004 a4 b6 1.9 tdi cvt.
    I was driving and noticed that my lights were on. I turned the rotary light switch to the ON position and the lights seemed to switch to the fog lights properly. When I turn off the engine the lights go off. The off position on the light switch leaves the lights on and I cannot turn them off.I have changed the switch and still have the same problem. Any ideas experts.
  2. Re: Lights will not turn off
    Dec 2009
    southampton uk
    If its not the switch I think you will need diagnostics to check whats happening
  3. Re: Lights will not turn off
    Apr 2013
    gosport uk
    Thank you for the reply. I have looked up the electrical system in the Haynes manual. They list a relay in the circuit as 17 'X' contact relay. Do you know where this relay is mounted so I can check it before I start looking at the power supply control unit.
  4. Re: Lights will not turn off
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Run web searches for central electronic control module.
  5. Re: Lights will not turn off
    Apr 2013
    gosport uk
    If it was the switch that was faulty, now I have changed the switch would a fault code still be in the system?. If so how do I clear it.
  6. Re: Lights will not turn off
    Southern County Softy
    20 Post(s)
    Was the new switch the same part number ?
    There are different revisions of switches.
    A4 2.5 tdi QS (mapped)
  7. Re: Lights will not turn off
    Apr 2013
    gosport uk
    The switch was identical. The part numbers matched each other. Does anyone know where the switch relay and power control module is located please.
  8. Re: Lights will not turn off
    Apr 2013
    gosport uk
    Update on lighting situation. Looks like the vehicle electrical system control module has become faulty. I have been quoted £251.00 +vat by the local VW indy to supply the unit. Is it necessary to program this module once it is installed?. Part number is 8E0907 279F
  9. Re: Lights will not turn off
    Apr 2013
    gosport uk
    Update on lighting situation. I bought a second hand module and fitted it today. Happy to report all lights now function correctly.
  1. Daylight Running Lights - How to turn ON?
    By smallpurplecat in forum Alhambra
    Last Post: 28-09-2014, 01:46 PM
  2. Can you turn on Rear Fog Lights without the Front ones?
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-11-2011, 08:52 AM
  3. interior lights wont turn off my vw sharan
    By anthony.morley in forum Touran - Sharan - Caravelle
    Last Post: 11-03-2010, 09:37 PM
  4. Question Revs drop to 0 when i turn on my lights
    By bill2989 in forum Golf MK2 - 1984 - 1992
    Last Post: 15-07-2009, 11:53 PM
  5. Interior lights wont turn off
    By Steve N in forum Superb
    Last Post: 08-03-2009, 02:53 PM
