Re: A4 TDI 2009 B8 - Starting problems –
05-10-2015,11:52 AM
Yes you can code yourself, if your new battery has the same characteristics as old one. Just change last digit of serial number which is already there,VCDS (screen 19-CAN@gateway _> Long Adaptation -> Channel 4 -> Battery identification) etc...
Find somebody with cable in your area, 5 minutes job. Still cant belive its coding issue only, but you can try-out.
Not sure about this code reader - is there possible to change codings in modules!!!
A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
