Thread: Lumpy running under load
  1. Lumpy running under load
    Taunton
    2001 Passat diesel Tdi AWX .167000mls
    Just had clutch and flywheel done because of judder. Since then engine has now got a bad shuddering when accelerating under load,eg steep hill.Does not seem to be clutch as this quite smooth in operation.. My question, stupid as it might seem is, Could a sensor have been disconnected or as the battery was disconnected could this have affected the engine management system. It seems too coincidental that it was OK before the fitting of the clutch. There is no black smoke,fuel consumption is normal and engine does not use any oil.Also runs perfectly other than trying to accelerate up hill..
    Any ideas or advice would be appreciated..
    Howard...
    So much time..So little to do!!!
  2. Re: Lumpy running under load
    Pembrokeshire
    22 Post(s)
    no, sounds like something has been done wrong...
  3. Re: Lumpy running under load
    Oct 2015
    GB
    Maybe a mount is loose or needs tightening, like the gearbox mount.
    Best take it back ASAP just to double check, my mates car recently had a judder and he left it till it was too late,
    And a Bolt worked itself loose on the gearbox which led to the engine & gearbox swinging which ended in crunched gears and a recon gearbox.
    Green locctite should be used at all times.
    Sent from my SM-A300FU using Tapatalk
  4. Re: Lumpy running under load
    Taunton
    Follow on to this problem. Took it back to garage and all checked out on ramp. They allowed me to witness that all was tight and mounts all OK. Turns out the problem is ME! I tend to let the revs drop too low and if I try to give it welly at or under 1000 rpm it protests (rightly so!) if the gear is too high.( My excuse is I am a bus driver used to low revving diesels!) I feel a right prat! Thanks to the replies, sorry to be a time waster!
  1. How To Home Service - running lumpy under load
    By portovechios in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-01-2012, 12:48 AM
  2. Question Lumpy Running
    By Teflon in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-05-2011, 07:28 PM
  3. Please Help Passat 1.8T (AWT) 2004 Lumpy acceleration under load when pulling away in all gears
    By Captain Babble in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-09-2010, 06:25 AM
  4. Lumpy Running
    By Tel254 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-10-2009, 09:27 PM
  5. Lumpy Running
    By russell.green2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-04-2009, 08:11 PM
