Thread: Fuse keeps blowing! No Power! Brake light always on!
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Fuse keeps blowing! No Power! Brake light always on!
    1841 Post(s)
    Are you sure you have disconnected the EGR valve and tried it? They get full of oil and blow the fuse.
  2. Re: Fuse keeps blowing! No Power! Brake light always on!
    Sep 2017
    hull
    Quote Originally Posted by Sinny Sivapalan View Post
    Seems to be easy, I'll give it a go tonight. Btw I put another 15a fuse in the blue holder and suprisingly when I started the car it did not blow so I immediately cleared the codes and did another scan and I got these codes
    - P2413 - Exhaust Gas Recirculation System Performance.
    Then the fuse blew when I was driving and could hear the turbo spooling, limp mode no power usual things.
    Dif you resolve the problem im having the same symptoms
    Sent from my SM-G935F using Tapatalk
  3. Re: Fuse keeps blowing! No Power! Brake light always on!
    Sep 2008
    Bolton Lancs
    6 Post(s)
    As the post is around 2 years old I would of thought he got it sorted have you tried the solutions in the comments on here
  4. Re: Fuse keeps blowing! No Power! Brake light always on!
    Sep 2017
    hull
    Quote Originally Posted by markspark71 View Post
    New to this sorry just sorted today maff wire melted on turbo
  5. Re: Fuse keeps blowing! No Power! Brake light always on!
    Sep 2008
    Bolton Lancs
    6 Post(s)
    No need to apologise I did notice you was new and didn't want you thinking the forum is rubbish as no one replied glad you got it sorted and welcome to the forum
    Sent from my SM-G950F using Tapatalk
  6. Re: Fuse keeps blowing! No Power! Brake light always on!
    Mar 2022
    Uk
    Hi Crasher, I've just swapped a replacement blb engine into a b7 a4 and having the same 15a fuse in ecu tray blow. Have disconnected brake light switch to rule out and no change. Would you suggest running the car with egr disconnected to clean out oil? The car did have turbo and oil pump failure so there is oil in inlet tract. Thanks
  7. Re: Fuse keeps blowing! No Power! Brake light always on!
    #17
    1841 Post(s)
    You would get a better response if you start your own new post and included the VIN's of both vehicles if possible or PM me the reg's if you don't.
  1. Brake Light Fuse blowing repeatedly
    By dmoore in forum Golf MK4 - 1999 - 2004
    Last Post: 29-07-2016, 05:44 PM
  2. kl.15 fuse constantlt blowing - also econ light has come on and air con not working
    By billyfurey in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-09-2011, 06:32 PM
  3. Brake Light Bulbs - Blowing
    By huddsa4tdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-01-2010, 08:20 PM
  4. Brake light fuse keeps blowing
    By LLOYDZIMMER in forum Golf MK4 - 1999 - 2004
    Last Post: 16-09-2009, 03:11 PM
  5. Please Help Continually blowing rear brake light bulbs
    By daled in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-01-2009, 10:19 PM
