Thread: Oil lamp on with low rpm 1.8t aeb
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Oil lamp on with low rpm 1.8t aeb
    May 2015
    Norway
    Hi! When the engine is hot andre I drive with low rpm, aprox 1000-1500 for a few minute, the red oil kamp blinks andre IT giver a beep sound. IT gies away if I drive with rpm on 2000 or higer I few sec. IT Comes back after a few minutes if I drive with low rpm again.
    For a little White ago I used motor flush.
    Amy tips ? Take of the bottom Pan ans clean a filter inside Therese maybe ?
  2. Re: Oil lamp on with low rpm 1.8t aeb
    Pembrokeshire
    22 Post(s)
    don't use the car until its cured. the flush has probably knocked a load of crap out which is now in the sump. so, sump off, clean, etc...
    0 2 0
  3. Re: Oil lamp on with low rpm 1.8t aeb
    May 2015
    Norway
    Thanks for answer. Do you have a guide to take off the oil pan ?
    Is it hard ?
  4. Re: Oil lamp on with low rpm 1.8t aeb
    Pembrokeshire
    22 Post(s)
    drop subframe, remove sump.
  5. Re: Oil lamp on with low rpm 1.8t aeb
    May 2015
    Norway
    Thanks for answer. how does i drop the subframe the easyest way ?
    And the bolts for the sump, is they hard to get ? Did see a video from A4 and there they needed to crank the engine to getting to two bolts in the gear box ?
  6. Re: Oil lamp on with low rpm 1.8t aeb
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Did you replaced the oil filter, after you made the engine flash?
  7. Re: Oil lamp on with low rpm 1.8t aeb
    May 2015
    Norway
    Yes I did. And the oil did not see very dirty too.
    Can it be the oil pump?
  8. Re: Oil lamp on with low rpm 1.8t aeb
    Pembrokeshire
    22 Post(s)
    there are a couple of bolts hidden at the back where the sump joins the gearbox. they are a bit fiddly to get to and you will need a small 10mm socket on an extension or a 6mm allen key , a long one. you turn the flywheel until you can get to them. the subframe needs lowering, just undo the mounts and lower it but you then need to align it when it goes back in.
  9. Re: Oil lamp on with low rpm 1.8t aeb
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    It's an option. But I suggest you go from the easy to the heavy. Check whether the engine oil is not too thin (flash material residues). In the oil system has oil pressure release valve If it is stuck this can Cause similar results. How many miles \ KM on the clock?
  10. Re: Oil lamp on with low rpm 1.8t aeb
    1841 Post(s)
    It will be crap in the sump as Zolly says, playing around with other ideas is like playing Russian roulette with your turbo at the least. The sump will need to be cleaned out and for this I use paint stripper to avoid damaging the sumps shiny surface which helps reduce the dirts ability to cling. The inside of the cam cover and head will also be covered in sludge. This is why I always warn people about oil flushes, they can cause more problems than they solve.
  1. 1999 1.8T AEB (petrol) Checking the low tension & power to injector?
    By anorak_ian in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-09-2015, 10:10 AM
  2. Rough idle and low rpm
    By NickyR1983 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-05-2013, 06:25 PM
  3. Oil light flashes at low RPM
    By wpisme823 in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2010, 09:52 PM
  4. Please Help grinding noise at low rpm.
    By rzlez7 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-07-2010, 01:12 AM
  5. golf jerks in low rpm
    By shorty in forum Golf MK4 - 1999 - 2004
    Last Post: 02-02-2009, 01:58 AM
