Thread: Ballast unit for adaptive light in a A4 TFSI Quattro ( 8E )
  1. Ballast unit for adaptive light in a A4 TFSI Quattro ( 8E )
    Sep 2015
    Weymouth
    Can anyone help - Im trying to locate a ballast unit for the above model. Problem is I don't know what the original or subsequent parts numbers are. I believe that the original unit is a 8E0 941 329, does anyone know if a 8E0 941 329A will work? or some other unit?
    I know that the correct part No now is 8P0907391 - which is an eye watering £450 before fitting from Audi. Hence my search for an older one.
    I have tried a serial ( not part No - not sure what the part No is ) 1 307 320 127 which looks totally identical and definitely does not work.
    Louis
  2. Re: Ballast unit for adaptive light in a A4 TFSI Quattro ( 8E )
    1840 Post(s)
    The control unit J667 was 8E0 907 391 C up until 12/2006 when it changed to the series two A3 part number 8P0 907 391 which is £423.29.
  3. Re: Ballast unit for adaptive light in a A4 TFSI Quattro ( 8E )
    Jan 2012
    Coding Something
    I may have 1 in stock from an install, its still a few hundred, I'd need to check tbh, let me know if you still require 1.
  1. Adaptive Light Defective
    By papadelta in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-07-2015, 04:35 PM
  2. Access code for engine control unit...A4 2.0L TFSI 8K '10' chassis?
    By baylissboy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-02-2015, 08:22 PM
  3. Please Help A8 E3 dynamic cornering light, adaptive light not working
    By astrafax in forum A8 - S8 - V8
    Last Post: 15-12-2011, 10:25 PM
  4. Adaptive cruise control radar unit needed
    By philsayer in forum A8 - S8 - V8
    Last Post: 18-05-2011, 01:10 PM
  5. ADVICE PLEASE = 2.0 TDI(170) quattro or 2.0 TFSI quattro??
    By missscotia in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-01-2010, 11:15 PM
