Thread: Bobby Singh's Audi A4 3.0 TDI Project car
Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 100
  1. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #81
    Jul 2007
    Windsor
    December 2020
    Gave the car to my cousin from TeamSPB who also runs a car detailing business called "Reflective Detail".
    Main objective was to make a custom gauge pod for the turbo shaft speed, however while he had it he asked if I needed it back in a rush...I replied with a nervious no.
    But wow he gave me a amazing surprise with a level of detail I've only read about. Im not really sure which combo of pads, wax, sealant etc he used but the job is the best I've seen.
    Gauge pod:
    Detail inside:
    before:
  2. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #82
    Jul 2007
    Windsor
    Inprogress:
    Finish:
    Little video:
    Bobby Singh's Audi A4 3.0TDI - Reflective Detail - YouTube
    Bobby
  3. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #83
    Ireland
    Looks stunning, and drives even better.....
    Great work...
    2001 allroad 2.5 AKE manual -gone
    2007 A6 Estate 2.0 BRE manual
  4. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #84
    May 2012
    Everywhere
    308 Post(s)
    Stunning transformation .
    lukla you've some challenging cars there .
  5. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #85
    Jul 2007
    Windsor
    January 2021
    First modification of the year - Flat bottom steering wheel:
    Feels faster already
    Bobby
    0 2 0
  6. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #86
    Jul 2007
    Windsor
    Gear knob arrived - part number 8K2713139S
    JXB performance bearing carrier arrived in case the stock one gives up again:
    Bobby
  7. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #87
    Jul 2007
    Windsor
    January 2021
    R110 fuel pump finally running, as per my post in Jan 2020 I've been trying to get this pump running.
    I had it running but during high rail pressure it would leak causing the Vee to become a swimming pool.
    Here are some pics during the development
    Custom gearbox pump plate:
    Rail pressure output valve changes:
    R110 pump:
    Even thought about custom gears to spin the pump faster:
    After long last R110 is now working without leaks.
    Thanks to @Horia for his support and many others who support me through other social media sites.
    Bobby
    0 2 0
  8. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #88
    Jul 2007
    Windsor
    Febuary 2021
    Sourced a 4 bar boost gauge in preparation for some more boost Access denied
    Moved the boost gauge to the pillar pod gauges and the turbo speed gauge to the centre vent.
    Gauge comes with a pressure sensor which I mounted in the EGR blanking plate
    Cylinder pressure tool arrived finally - Very expensive sensor:
    Bobby
  9. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #89
    Jul 2007
    Windsor
    March 2021
    Been spending some time on pushing the engine further and making decent progress.
    I've installed a injector current clamp and now can see the injection events per cycle:
    Learning a lot from this tool for example x deg timing can add y bar of cylinder pressure depending on RPM - having big injectors is a must.
    Turbo is now pretty much max (safe limit) and emp is now in the positive range, so measured the exhaust back pressure (still using the stock system apart from the downpipe) and it showed a peak figure of 450mbar.
    Looking at the stock back boxes you can see Audi engineers put some thought into the design:
    As a test I decided to open the second port on the back boxes:
    Welded in a 90deg 57mm elbow - JEEZ wow its so loud haha totally unbearable.
    End result was 60mbar drop - hardly worth the effort and rather save my ears so will be welding that back up.
    Will look into the rest of the system to see if I can gain any flow, but so far I see no benefit of changing the back boxes.
    Bobby
  10. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #90
    Mar 2021
    Sunderland
    Hi mate am after remap could you pm thanks
  1. Audi RS2 Sedan Track Day Car - Project
    By RS2_sedan in forum Chat - Anything with wheels
    Last Post: 28-01-2013, 05:52 PM
  2. Project: Singh's Rocco
    By d.singh in forum Scirocco - Corrado
    Last Post: 27-08-2012, 06:14 PM
  3. C5-A6 Avant project car - Car Mechanics
    By ellaguru2u in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-02-2010, 08:39 PM
  4. Bobby Robson RIP
    By Hex69 in forum Chat - Completely Off Topic
    Last Post: 08-08-2009, 03:23 PM
  5. New Project Car
    By andy01745 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2007, 09:20 PM
