Thread: Bobby Singh's Audi A4 3.0 TDI Project car
Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 100
  1. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #51
    Jul 2007
    Windsor
    Quote Originally Posted by Gazwould View Post
    Still not as fast as a BITDI !
    Haha yes
    But it seems like he has now realised the difference between butt dyno and timed runs
    1 1 0
  2. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #52
    Jul 2007
    Windsor
    100 to 200 in 9.7seconds
  3. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #53
    Jul 2007
    Windsor
    April 2018
    Been a while but been busy on other projects.
    I had a issue with a leak on the oil return line rubbing on a bolt:
    So decided on a banjo fitting @ 30deg which gave me perfect clearance with new a -10 hose
    Also, BW do a compressor housing which according to the compressor map had less surge so this was installed at the sametime:
    On a side note these are the best clamps I have ever come across - they apply fixed torque regardless of temperature changes.
    So far the results are very good I can demand more torq low down without going into surge
    Plenty air available top end.
    Next little project will be to measure cylinder pressures
  4. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #54
    Jan 2013
    Wessex. and Southern France
    108 Post(s)
    Excellent, as always.
  5. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #55
    Jul 2007
    Windsor
    July 2018
    PCP findings are interesting, lets just say its amazing the heads are still on
    Cleaned out the intank fuel pump:
    When 4 bar map sensor is no longer enough - 6 bar sensor fitted.
    The probe is 18mm and the plastic hard pipe does not have enough material to drill it out.
    Bobby
  6. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #56
    Sep 2018
    Peterborough
    Very nice build where did you get your zf gearbox service kit do I have the same box as you myne is the 6 speed tiptronic Audi code is LMK
  7. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #57
    Jul 2007
    Windsor
    Its was from a German ebay seller - look for zf 6hp 28 service kit we have a steel sump.
  8. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #58
    Jul 2007
    Windsor
    September 2018
    Nothing new to report but now have covered 10k on the new the turbo set up.
    Done some more testing with a couple of new gearbox tunes:
    0 - 60 - best i can get is 4.2s (same as before)
    0 - 100 has improved 8.7secs (previously was around 9.3s)
    All timed with VCDS @ 20hz
    Looking at the 0 to 100 I would say high 11's is on the cards. Just need to find the time to do a few runs
  9. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #59
    Jul 2007
    Windsor
    September 2018
    For the last few months I've been getting chain rattle on start up.
    Didn't think much of it as it cleared pretty quickly.
    However, before things got worse I thought I'd take a gamble and change the tensioners and guides on both banks before taking the engine out to do all the chains etc.
    Febi chain kit (oem)
    RHS bank
    LHS bank
    Wearing:
    The old tensioners appear to be leaking/not holding pressure until the engine oil pressure was enough.
    Covered approx 500 miles and no rattle so far.
    Worth doing these first I suggest if anyone gets the same issue.
    September 2018
    In preparation for some drag racing action. I found some private land and done some testing
    Gearbox tune is working well:
    Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
    Finally cracked sub 4s to 60mph (96km/h) ~ 3.9s
    0 to 100 is 8.3's
    I was looking at my 12.3s (best at Santa Pod 1/4 mile time logs and on that run I hit 0 to 100 in 9.79s so approx 1.5's quicker now
    Should be interesting
    Bobby
  10. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #60
    Jul 2007
    Windsor
    Anyone watching this thread and wants big power you may want to consider this:
    https://www.audi-sport.net/xf/thread.../#post-3322627
  1. Audi RS2 Sedan Track Day Car - Project
    By RS2_sedan in forum Chat - Anything with wheels
    Last Post: 28-01-2013, 05:52 PM
  2. Project: Singh's Rocco
    By d.singh in forum Scirocco - Corrado
    Last Post: 27-08-2012, 06:14 PM
  3. C5-A6 Avant project car - Car Mechanics
    By ellaguru2u in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-02-2010, 08:39 PM
  4. Bobby Robson RIP
    By Hex69 in forum Chat - Completely Off Topic
    Last Post: 08-08-2009, 03:23 PM
  5. New Project Car
    By andy01745 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2007, 09:20 PM
