Thread: Bobby Singh's Audi A4 3.0 TDI Project car
Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 100
  1. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    Dec 2014
    Mumbai, India
    HI Bobby,
    My questions below
    1> Wagner tuning does not offer a FMIC for the Audi A6 3.0tdi but offers upgraded twin side mount intercoolers . Does it make sense changing them @ GBP750/-
    2> Are you running a stock or Hybrid Turbo
    3> If Hybrid specs and bought from whom
    4> The remap - Have you done it yourself or from a tuner. If needed can the map be sent to me/purchased if I were to replicate your setup. Reason am asking is I dont have access to a 4 wheel dyno in Mumbai and would save me a whole lot of time and effort in getting the tune right by doing a road tune(done ny tuner not me)
    Jignesh
    None of the products will be available in India and am aware that I will have to import the same.
    2009 Audi A6/C6 3.0 tdi quattro remapped stage 2 with full Miltek catback exhaust & K& N filter
  2. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    Jul 2007
    Windsor
    My questions below
    I can arrange for a Wagner intercooler if it helps
    Stock GTB2260VK
    Yes I tune cars and this is my own - as you can see takes a lot of research and development to workout what is actually required rather than just throwing parts in to a car.
    Im sorry but I'm not prepared to mail you a tune as when I flash a car I add some protection - hope you understand
    Bobby
  3. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    Jul 2007
    Windsor
    27/9/15 - Egr and Swirl flaps delete
    Updated post 2 and 3 - enjoy
  4. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    Jul 2007
    Windsor
    4/10/15 - Exhaust Manifold Pressure measurement taken and updated post #3
  5. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    May 2012
    essex
    Just found this thread and loving it!
    Interested in your thoughts on injectors and fuel pumps, I've spent am eternity inquiring about upgraded items only to be disappointed.
    My asb with hybrid bv50 is limited by fueling.
    Got a link to wagner smic as can't find them?
    2007 3.0tdi le mans
    hybrid turbo, decat,miltek, 20's etc
    330-350 bhp
    450-500lbst
    2007 3.0 tdi le mans : Hybrid turbo decat : miltek etc : 330-350 bhp : 450-500lbsft
    Visibility pack. Adaptive xenon, Privacy glass. Bose surround. Dvd nav. Comms pack, led plate lights.
    Miltek, custom map,hybrid turbo, decat improved airflow to intercoolers.
  6. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    Jul 2007
    Windsor
    Quote Originally Posted by bops6 View Post
    2007 3.0tdi le mans
    330-350 bhp
    450-500lbst
    What pump do you have fitted to your car?
    From the BV50's I've tuned in the past you should have a CP1H?
    If so you shouldn't be getting fueling issues at 670nm.
    Do you suffer from rail pressure drop? And do you have any logs IQ?
  7. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #17
    May 2012
    essex
    Still running standard pump and injectors.
    Never even got round to dyno the damn thing. Just educated numbers.
    No logs either lol
    Just what I've been told about fueling by couple of tuners.
    Not very helpful am I.
    Sorry
    Couldn't find a tuner in South east with experience with this engine when I has the turbo fitted.
    2007 3.0tdi asb le mans
    330-350 bhp
    450-500lbst
  8. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #18
    May 2012
    essex
    There's an offer I might take you up on 👍
    I know my current map could be improved and the couple of respected tuners with dynos I have talked to want large £'s for the maps which I never got round to.
    330-350 bhp
    450-500lbst
  9. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #19
    Jul 2007
    Windsor
    Firstly many thanks to Stuart who has kindly unlocked this thread.
    The car has made very good progress and I will update it now.
    Enjoy
    1 1 0
  10. Re: Bobby Singh's Audi A4 3.0 TDI Project car
    #20
    Jul 2007
    Windsor
    10/10/15 - Inline coolant regulator
    So since removing the EGR cooler the coolant temp has been dropping to low as 50deg when on the motorway.
    This regulator use to be mounted on the EGR cooler:
    So from the egr cooler I cut out the mounting and also cut the 16mm pipe coupler to weld together.
    But the internal bore size is alot bigger on the regulator mounting:
    Ended up using a reducing 90 and it worked a treat
    17/11/15
    Updated the lighting on the car from Aurora Bulbs (great service). Fog light, interior bulbs, boot, and reverse.
    63mm intercooler pipe (turbo to intercooler)
    First getting the stock (50mm pipe) out is a pain - I ended up cutting it at muffler:
    I wanted to see what was inside any how
    After some cutting I had a rough design:
    However, the 63mm pipe was too big for the Wagner silicone hose. There was a section in the hose that accepted 57mm, so ended up with this:
    Tapped some threads and fitted a NPT nipple to measure pressure drop rather than using a hose with a hole.
    The silicone hose which i used is very close to the exhaust manifold so have ordered some heat wrap and will need to fit a support bracket to hold the pipe up.
    In other news my exhaust is ready
    Great quality item - custom made 3" with V band connections and ear friendly big mufflers.
    2/12/15 - 3" Exhaust fitted
    Well I fitted the 3" exhaust during the weekend and to be honest it looks great and sounds great. But I'm not sure I can live with it.
    I'm basically doing a lot of miles and I always wanted a stealth but fast car.
    It does look good:
    As for performance well its the best I've seen with zero back pressure at 4.6k rpm and only 45mbar in the midrange.
    Im sure its old age but I want my car to be silent. So I'll be fitting the standard system back which was giving me 130mbar still not so bad as the 2260 has to deal with at least 500 to 600mbar with the dpf.
    In the future if I find the back pressure is too high then maybe I'll fit a active exhaust valve.
    I've also now found the limit of the CP4.2 pump - I can get 97mg in the mid range with 81mg @ 4k before rail pressure becomes a issue.
    Still smoke free which is great - time for another dyno i think.
  1. Audi RS2 Sedan Track Day Car - Project
    By RS2_sedan in forum Chat - Anything with wheels
    Last Post: 28-01-2013, 05:52 PM
  2. Project: Singh's Rocco
    By d.singh in forum Scirocco - Corrado
    Last Post: 27-08-2012, 06:14 PM
  3. C5-A6 Avant project car - Car Mechanics
    By ellaguru2u in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-02-2010, 08:39 PM
  4. Bobby Robson RIP
    By Hex69 in forum Chat - Completely Off Topic
    Last Post: 08-08-2009, 03:23 PM
  5. New Project Car
    By andy01745 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2007, 09:20 PM
