Thread: audi a6 3.0tdi avant tiptronic vibration issue
  1. audi a6 3.0tdi avant tiptronic vibration issue
    Aug 2014
    dorset
    Hi all, still have this vibration problem with my audi. it happens around 2000 rpm but only when warm, almost like a buffeting vibration which then clears around the 60mph mark. The car has recently had new tyres,allignment check, rear pads and a new handbrake cable, and then passed its MOT. The garage man said it has him stumped as to what it could be. I have read that a transmission flush and filter could be in order but the mechaic was weary to do this because of cost and might not sort the problem.
    Apart from this the car is fine and not down on power etc and according to the mechanic all drive shafts and prop seem fine. My only concern is I am moving to Italy soon and have to drive the car down there and would much rather have this sorted prior to leaving.
    She has done 130k and was fully serviced recently and had a new throttle body fitted due to fault code showing, we have had the car now for 12 months and this vibration did not surface until 8 months into ownership. Any help/advice would be so much appreciated. Thanks all
  2. Re: audi a6 3.0tdi avant tiptronic vibration issue
    Jul 2015
    Staffs
    46 Post(s)
    Where do you feel the vibration? ie steering wheel, through whole car?
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: audi a6 3.0tdi avant tiptronic vibration issue
    Aug 2014
    dorset
    Quote Originally Posted by rowdy-999 View Post
    Its felt thru the whole car, very apparent to driver and passenger. jp
  4. Re: audi a6 3.0tdi avant tiptronic vibration issue
    Jul 2015
    Staffs
    46 Post(s)
    Engine / box mount?
    I would take it to a specialist for advice.
    Ian
  5. Re: audi a6 3.0tdi avant tiptronic vibration issue
    Nov 2012
    Somerset UK
    As mentioned earlier you do need to get it scanned with VCDS.
    ZF recommends fluid and filter change by 80k and then every 50k from then on. I had mine done at 82k but didn't have any vibration issues just a jerkiness when changing down from 3rd, 2nd and 1st which generally disappeared since the change.
    There's also an internal bolt tightening sequence that should be done when the tranny pans been dropped with improves the gearbox
  1. A6 2.0TDI Avant S Line 2012 C7 Interior Lights issue.
    By Tigerdaly in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-01-2015, 11:08 PM
  2. Audi A4 Tiptronic starting issue
    By davymac67 in forum Chat - Anything with wheels
    Last Post: 12-04-2014, 11:10 AM
  3. A6 Avant Tiptronic gearbox issue
    By tartanpaint in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-11-2011, 01:33 PM
  4. Question Vibration, A4 Avant 3.0Tdi quattro tip.
    By rmaxibiza in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-12-2008, 10:53 PM
  5. Audi A6 avant 2.4 1999 tiptronic steering wheel vibration (slight and intermittant)
    By mangled_harry in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-08-2008, 08:50 AM
