Thread: burnt out resistor?
Results 1 to 9 of 9
  1. Angry burnt out resistor?
    Sep 2015
    Canterbury, England
    Hi there, I'm new to this site so I'm not sure if this is the right area but I hope it is.
    So I got myself a 1999 A3 3dr hatchback, thought I'd clean it up with some fresh LED lights for the interior, I managed to get 3 LEDs into the rear interior light and 2 boot lights but the 5 up front hadn't yet been changed and realised I didn't have enough, so thought I'd order some more and now (3 days later) it'd seem a resister has burnt out and started to burn the plastic housing too.
    not sure whether its because front interior lights are bulbs and the rear is an LED or whether it needs something more? should I have waited and kept all bulbs in until I had all LEDs?
    problem is now, I have no idea what to do. Do I just replace the resistor in the light housing? (solder + new resistor?) What type of resistor would I need?
    Thanks in advance?
  2. Re: burnt out resistor?
    Pembrokeshire
    22 Post(s)
    can you post a pic of what you are on about..
  3. Re: burnt out resistor?
    Sep 2015
    Canterbury, England
    Yeah, so here is a pic of the front interior light.
    As you can see its burnt the plastic around it. I don't know whether to solder a new, better resistor into it or whether it's completely ruined.
  4. Re: burnt out resistor?
    Pembrokeshire
    22 Post(s)
    they are diodes, not resistors.
  5. Re: burnt out resistor?
    Sep 2015
    Canterbury, England
    Ah I see, I'll have to tell Mr mechanic down the road then cheers. So now I know the name, what do I do about the problem?
    Can I just switch all interior lights to LEDs then it should be fine? What type of diode would I need to replace it with?
  6. Re: burnt out resistor?
    Pembrokeshire
    22 Post(s)
    you want whatever is already fitted, or get down a breakers yard and get another light.
  7. Re: burnt out resistor?
    Sep 2015
    Canterbury, England
    So can I not put LEDs into the inside of my car? Or should I have changed them all at the same time? Can I not get a diode that would work with LEDs?
  8. Re: burnt out resistor?
    Pembrokeshire
    22 Post(s)
    the diode just stops current backfeeding through it. it has nothing to do with the leds, but diodes do sometimes just fail. replace the diode, fit your leds and forget it.
  9. Re: burnt out resistor?
    Sep 2015
    Canterbury, England
    Thanks for the help. I'll order one right away and hope it all goes well
  1. Please help - Coil burnt, what to do next?
    By KBX10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2011, 07:17 PM
  2. Resistor Value
    By Cpt Shed in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-06-2011, 08:23 PM
  3. Burnt out clutch
    By richie_jones in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-04-2011, 05:42 PM
  4. Please Help Resistor Unit???
    By Windybear in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 10-10-2009, 11:51 PM
  5. Burnt Tube
    By Fred Thornton in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-07-2009, 08:27 AM
