Thread: audi a6 3.0tdi Quattro la mans 2008
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: audi a6 3.0tdi Quattro la mans 2008
    #11
    Motherwell
    Quote Originally Posted by B5NUT View Post
    Can you try and connect to address "02-Auto Trans" as it not showing up on the auto-scan. Also looking at the fault codes it could be a bad connection to the gearbox ECU or the ECU on it's way out.
    When scanning it is as if the transmission is disconnected from the car, when the car heats up to running temp the gearbox returns and there is no faults on 02-Auto-Trans and all the other failts can be cleared and will not come back.
  2. Re: audi a6 3.0tdi Quattro la mans 2008
    #12
    May 2014
    Darlington
    78 Post(s)
    I would check the harness & connectors going to the gearbox, if that all looks good then the ecu is faulty. Could be a bad joint which makes as the heat build up and things expand.
  3. Re: audi a6 3.0tdi Quattro la mans 2008
    #13
    Jun 2007
    Did you ever get this fixed ? If so what did it turn out being ? Thanks
  4. Re: audi a6 3.0tdi Quattro la mans 2008
    #14
    Jun 2007
    Does anyone know if " Kegsie " is still a member ? I'm trying to find out if he ever resolved the issue.
    Thanks Simon
  1. 2008 A6 Le mans 3.0tdi Autowith Koni FSD Help
    By jugghead in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-04-2015, 08:16 AM
  2. Rear disc size on 2008 Le Mans 3.0 quattro saloon
    By furfurfur in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2013, 05:45 PM
  3. Wheels from an A6 2.0Tdi Le Mans to A5 2.0 Tdi Quattro
    By Andy Grob in forum Wheels and Tyres
    Last Post: 02-05-2013, 01:45 PM
  4. Replies: 10
    Last Post: 17-04-2013, 10:06 PM
  5. Just bought me an A6 3.0TDI Le Mans Saloon 2008
    By invisiblekid75 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-02-2013, 01:21 AM
